steering shaft
Old 01-18-2005, 05:01 PM
the501clique's Avatar
steering shaft
got a question
i have to make a custom steering shaft and wanna use flaming river or borgeson products because i need to add universal joints to the shaft. its a 1993 toyota 2wd pickup w/o power steering. and i was wondering if you guys could help me find the spline size on my steering box so i could start designing my new system from there.
thanks for your time
Old 01-18-2005, 09:04 PM
4Crawler's Avatar
Why not get a 4WD shaft, has u-joints on each end, can be extended or collapsed to a wide range of lengths and probably has the right splines to start with:
U-joint at the top:
U-joint at the bottom:
More info:
http://www.4crawler.com/4x4/ForSale/...#SteeringShaft
The '88/9 and older shafts are adjustable for length.
Old 01-19-2005, 03:46 PM
i dont know if a 4wd is gonna fit and im not sure thats gonna be the solution to my clearance problems plus this is a show truck and i can get the aftermarket parts with a plated or stainless finish which would look alot better
Old 01-19-2005, 04:19 PM
4Crawler's Avatar
OK, was not aware of your requirements, just offering a suggestion. One sure way to get the size of what you have is to pull it out and measure and then see what is the closest SAE size to work with.
Jcrawl94
10
10-24-2015 04:34 PM
4x4-runner
08-30-2015 08:55 AM
CratesCruiser
08-23-2015 06:12 AM
4x4-runner
08-02-2015 09:24 AM
yoterr
07-24-2015 04:29 AM
Quick Reply: steering shaft
