Starting Problem after swap
Old 05-17-2004, 08:07 PM
patterson's Avatar
i just swapped out my v6 out of my 90 toy 4x4, for a different but same engine, everythings wired up, but imnot getting any spark, i believe i fried the coil, what are some possible causes of this and are there any easy fixes
kinda of confusing because im not very good with electrical bull
Old 05-17-2004, 08:33 PM
Forerunner's Avatar
Umm.. assuming it is not under distributor cap, and that you tested for the spark from the coil and got none, I would check the coil and the igniter. The easiest way to do it would be to take the coil and the igniter from a friends car and plug it into yours. Alternatively, you can get specs for the coil from the net or a repair manual and test the coil with the ohm meter. Try autozone.com for free online repair guides.
But first and foremost, I would check all the wire connections. Maybe something is loose after reassembly.
Crazychris1871
06-27-2016 10:38 AM
vasinvictor
01-20-2016 12:39 PM
Alex Bessinger
06-28-2015 10:05 AM
Edionne13
06-21-2015 11:37 PM
duckhead
3.4 Swaps
7
06-18-2015 06:54 AM
Quick Reply: Starting Problem after swap
