SS lift... help me choose
Old Mar 1, 2008 | 06:41 PM
Guest
Guest
Posts: n/a
ok so i blew out the shocks in my 97 4runner 5spd 4wd. you all know ive been looking around for my best option and changing my mind about 500 times. but I finnally settled on a Sonoran Lift either the #1 or 7. Im one of those people that like the best but the cost was kinda swaying me. Anyways so Im gonna be running 265/75r16 mostly due to this is a DD and mabey twice a month sees a trail. Ill be running Geolandar ATs.
My runner has stock bumpers but I plan on adding sliders soon and I already have a class 3hitch. I also have about 200-300lbs in the rear almost all the time as well as towing a small motorcycle trailer about 400 miles a month.
I know steve would be the best to ask but I want to hear your inputs as well.
Thanks for the input!
Old Mar 1, 2008 | 07:31 PM
Taro's Avatar
The 7 sits level but if your carrying all that weight all the time and towing it might sit low in the back. I'd go with the System 1.
Old Mar 1, 2008 | 08:12 PM
Guest
Guest
Posts: n/a
I was thinking the same might as well get the system 1 and if I go system 1 can I run 305/70r16 with mild trimming? or is 285/75r16 my max? without a whole buch of hammering and hacking? I meen really the only think between the 285 and 305 is width. mabey 1 in wheel spacers?
Old Mar 1, 2008 | 08:32 PM
4Runner202020's Avatar
i got OME 883's with the toytec top plate spacer and 890's with a 1 1/2 coil spacer in the rear no body lift and am runnin 305's no problem. 315's fit but i didn't wanna have to re gear so soon... but then again i got custom front and rear bumpers and hi clearence fiberglass fenders... just a thought.
Old Mar 2, 2008 | 12:11 PM
Nate08's Avatar
System 7 will also ride more harsh than system 1.
Old Mar 2, 2008 | 12:59 PM
rdang's Avatar
With all the research I did prior to purchasing my suspension lift, the SS 1.1 was the only lift kit that I could find that no one was bad mouthing, every other kit I saw had some sort of negative feedback.
If you want the best, it's going to cost you.
Old Mar 4, 2008 | 04:39 PM
Guest
Guest
Posts: n/a
Well I got a steal on some 245/75r16's Goodyear MTR's like new 5 for 500 so I couldnt pass that up. And I ordered my SS 7.2 lift as well. Ill post pictures when I install it hopefully the 18th or 19th of this month. And hopefully after that building my sliders and prerunner bumpers (not a fan of the ARB style bumpers). Thanks all for the help
Old Apr 2, 2008 | 12:24 PM
mayfield's Avatar
you have a transmission/steering cooler installed?
Old Apr 2, 2008 | 12:26 PM
rdang's Avatar
No... should I?
Old Apr 2, 2008 | 12:49 PM
mpavolka's Avatar
No... should I?
I don't know why this thread went to this but if your 4Runner is an automatic there is a tranny cooler in the radiator.
Old Apr 2, 2008 | 12:52 PM
mpavolka's Avatar
I have never owned or ridden in a truck with Cruiser Coils but I have the rear system #7.2 with the exception of OME 891's and I think it rides very well, better than stock or Downey springs I have owned. I can only imagine that the OME 890's would ride better, however I haul and tow a lot of weight.
Old Apr 2, 2008 | 12:54 PM
mayfield's Avatar
I should have sent him a private message asking him the type of transmissions he had. I purchased a SS 2.1 kit today, and will run 305/70/16 MTR's. i just wanted to know if fluid temps increased requiring him to install or upgrade cooling. thats all
Old Apr 2, 2008 | 01:00 PM
rdang's Avatar
Hahaha - sorry mayfield, thought you were taking a shot.
I have an automatic - I wasn't aware that I need any additional cooling for my 33's. Most guys on here recommend the transmission cooler and break upgrades if you go with a 35" tire, not a 33 so I never bothered.
Whether the fluid temps increased or not, I don't know - I would imagine that they did a bit, but I've driven an hour straight on the highway and no problems. Hope that helps.
Old Apr 2, 2008 | 01:30 PM
mayfield's Avatar
haha, no problem
Okay, i read the same thing on the forums that a cooler was required with 35
" ..I just wanted to check with you to see if you were experiencing any problems. this is good news for me! thanks for your post
the1998sr5
27
Nov 17, 2015 09:30 AM
thzpcs
Oct 3, 2015 07:39 AM
PureTacoma_Tundra
PureTacoma_Tundra
Sep 24, 2015 12:14 PM
sphealy
Sep 3, 2015 07:55 PM
Odin
Aug 30, 2015 11:44 AM
