Sign of an A/C leak? *pic*
Old 07-10-2008, 02:05 PM
Mason Dixon's Avatar
I went to look at my front sight glass to check for bubbles in the fluid and it appeared to be pretty greasy around the connections, is this a common symptom of a leak?
thanks fo sheezy
Old 07-10-2008, 02:20 PM
grovedogg's Avatar
looks like dripping engine oil... do you have a leak there?
the freon leaking (if substantial) would be a green color.... at least mine was
Old 07-10-2008, 05:11 PM
YodaPala's Avatar
Thats refrigerant oil b/c oil travels with the refrigerant. Probally just need to get some o-rings perhaps? Not to familiar with automotive air conditioning. I'm a Carrier tech armed with the smarts and the parts. Yeah very corny, I know.
Old 07-10-2008, 05:22 PM
iselloil's Avatar
Vac the system,buy a dryer,replace the o rings and re-charge.
Old 07-10-2008, 05:43 PM
Fink's Avatar
Hey Mason,
Would you mind resizing that pic to at least 800x600?
Thanks!
Fink
Old 07-29-2008, 10:33 PM
YodaPala's Avatar
did ya'all get er fixed?
Old 07-30-2008, 04:41 AM
BigBallsMcFalls's Avatar
a sign of leak is warm air when a/c is on full
the lines are full of gas, not grease, so grease on the lines indicate nothing
Old 07-30-2008, 05:59 PM
Fasterthanthedevil's Avatar
wow, that's some great resolution..what kind of camera do you have?
Old 07-30-2008, 06:02 PM
I haven't done anything with the drier yet, probably won't since I still decent cold air.
That is a fuji film f40 6meg pixel set on macro, pretty basic lil point and shoot
Old 07-31-2008, 10:20 PM
YodaPala's Avatar
You are totally in the wrong, the refrigerant(gas) travels with the refrigeration oil, so-if there is oil present, that is an indication of a leak.
Old 08-01-2008, 12:09 AM
gtfour43's Avatar
If you can see bubbles in that window you got a leak somewhere. By the looks of that drier it is leaking from the o-rings. Like previously stated: replace o-rings,vac system,recharge with new freon/oil.
Old 08-01-2008, 12:20 AM
Fo_SheeZy's Avatar
Resized...
MO transplant
04-23-2023 11:58 AM
jackiebrownia
07-20-2015 09:02 AM
the1998sr5
07-16-2015 06:20 AM
Avenged
07-09-2015 07:55 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Sign of an A/C leak? *pic*
