Should I replace my tranny filter?
Old 04-01-2003, 10:40 AM
DH6twinotter's Avatar
Hey all,
I lost quite a bit of tranny fluid while I was replacing my radiator. My original plan to plug up the tranny cooler hoses didn't work that great. Ended up scrambling around and used a couple of plastic bolts.
Anyhow, I lost about 5 quarts of fluid. Should I change my tranny filter now that I will be adding 5 or so quarts of new fluid? The 4Runner has about 168,000 miles on it, and I think the previous owners have had the tranny fluid replaced at least once. The fluid that did come out looks pretty good.
Well, thanks in advance.
Have fun all.
DH6twinotter
Old 04-01-2003, 09:11 PM
AgRunner06's Avatar
Post
I know that my 4runner is a 4wd, but when I had the transmission serviced they said that it didn't have a filter. They said all it is is a screen that collects any big particles. To clean this they had to drop the transmission pan, but I don't know what else they had to do to clean it.
Also, you might as well drain all your fluid and replace it with new fluid. I talked to a friend of mine that works up at Toyota and he said that they don't have transmissions in 4runners go out very often if the fluid hasn't been changed in a while.
Good Luck
Old 04-01-2003, 09:30 PM
Firefyter-Emt's Avatar
Yes.. have it flushed and cleaned/replaced.. IHMO best thing you can do to a slush box..
Old 04-01-2003, 09:37 PM
Robinhood150's Avatar
Yeah, it's got a screen that is just cleaned and put back. I think I'll be doing this clean and flush this weekend so I can answer this better then.
Steve
Old 04-02-2003, 07:16 AM
Zubaltec's Avatar
It's easy to do
Just drop the pan. Remove the 3 10mm that hold the filter. Clean it out real good with brake clean. Put it back in. Use a cork gasket that you get from Toyota for the pan. That silicon makes a mess and the cork gasket works great. just make sure you get all the old gasket material off the pan and trans surface where the cork will be touching.
Old 04-02-2003, 07:48 PM
Re: It's easy to do
Is the cork gasket specific for that particular tranny, or is it just generic cork gasket material that you cut yourself? I went down to toyota today to get the gasket and they said my tranny just uses RTV. Or do the 3rd gen trannies have a cork gasket?
Steve
Old 04-03-2003, 06:26 AM
Zubaltec's Avatar
Get the cork one
At my Toyota dealer the techs don't like using the RTV so they stock the cork ones. I can check with my dealer if yours doesn't have it.
Old 04-03-2003, 08:05 AM
Re: Get the cork one
Nah, that's ok. I need it by this sunday and little joe on ODW turned me onto some hi-tack sealant that should be better than RTV.
Thanks anyways,
Steve
Old 04-03-2003, 08:50 AM
Zubaltec's Avatar
Cool. Have fun.
Old 04-03-2003, 09:28 AM
Thanks you all. Been a great help. I'm going to go ahead and do all that today. I bought a kit from Advanced a while ago that includes a cork gasket and a new filter. I recken I'll just plop those in.
Hopefully my transmission won't break down on me with all the new fluid in there.
Thanks again all.
Have fun.
DH6twinotter
Old 04-03-2003, 10:39 AM
Zubaltec's Avatar
Anytime. Thats what we're all here for.
smthwsn357
12-04-2023 02:08 AM
Eggslinger
06-08-2019 03:32 PM
mskalmus
05-28-2017 07:51 AM
madxman21
07-09-2015 10:26 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Should I replace my tranny filter?
