Shocks
Old 11-30-2003, 04:03 AM
22Ryota's Avatar
Shocks
Wow... I am just burning up the forum lately. Thanks to everyone that helped the the pcv valve issue. I have a new question. I am not planning on lifting my truck but one of my shocks seems to be messing up or something. My truck has a slight lean to the drivers side front. This should be corrected if i replace both shocks right? it is noticeable. When i walk towards it in a parking lot i can see the lean and how it is not even. It isn't even when i am parked on level ground or unlevel groun New shocks to correct this? or what?
Old 11-30-2003, 05:03 AM
CTB
CTB's Avatar
I'm guessing it is probably a spring sagging on that side, not a shock issue.
Old 11-30-2003, 05:17 AM
MTL_4runner's Avatar
Yep, definately not a shock problem....I agree on a sagging spring problem instead.
Old 11-30-2003, 07:16 AM
GV27's Avatar
Ditto. Shock won't have an effect on ride height. It's the springs that hold the thing up off the ground!
Old 11-30-2003, 07:20 AM
Fink's Avatar
Could that be caused by a rear spring issue? If so then I would guess he doesn't have the Downey HD Coils and his rear end is still sagging too...might as well fix it all at the same time eh?
Fink
Old 11-30-2003, 07:30 AM
CTB
CTB's Avatar
Fink
Just to clarify, I believe he drives an older pickup, so he would have leaf springs in the rear, not coils.
Old 11-30-2003, 08:30 AM
outdoorfever's Avatar
but he said front not rear...and he only has shocks in the front correct?
Old 11-30-2003, 08:45 AM
CTB
CTB's Avatar
Good call, I missed the "front" part.
Old 11-30-2003, 09:08 AM
YotaChuck's Avatar
what year is the truck?
Old 11-30-2003, 12:13 PM
22Ryota's Avatar
87 pickup
Old 11-30-2003, 01:50 PM
22Ryota's Avatar
Ahhh ok.. a spring.. If i was taking it to a mechanic or buying one to have someone put on.. What would i call it? The front coil? Front driver side spring?
Old 11-30-2003, 03:41 PM
Cebby's Avatar
IIRC, the 87 has torsion bars up front (1 left, 1 right). Might be out of adjustment or one of the adjuster bolts has fallen (or rusted) out.
FWIW, he would have shocks at all 4 corners, not just up front.
As mentioned by others, shocks have no effect on ride height (unless they are "air" shocks that can be pumped up).
ladybugRC
458
08-21-2020 10:41 AM
ZGjethro
06-07-2017 11:04 PM
dirk89
10-01-2015 05:15 PM
ktm192k
10-01-2015 08:47 AM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Shocks
