shaking lights on bullbar
Old 06-04-2009, 09:37 PM
98runner210's Avatar
I have a bullbar. There are these tabs with foam underneath to mount lights on. When I am on a bumpy road the lights shake so bad the look like strobe lights and I am sure is very distracting to oncoming drivers. I just switch them off. Any ideas on stablizing them?
Old 06-04-2009, 10:00 PM
scuba's Avatar
Rubber in between the bolt and tab..?
Old 06-05-2009, 10:53 PM
already there
Old 06-06-2009, 12:45 AM
CRafferty's Avatar
increase the amount of rubber? I'm not sure there is anything else to do about it.
Old 06-06-2009, 05:02 AM
jdmaccord6's Avatar
which bull bar do you have? is it an ebay one? westin? I know the cheaper ebay bull bars are just not as stable as the westin bar. No matter what you do to the lights, the bar itself will still shake.
Old 06-06-2009, 05:32 AM
elblako91's Avatar
Shake the bar around with your hands and see if it moves. If it does try to find a way to stabilize it. More bolts and nuts or welding a support to it would help then you can do more of this
Old 06-06-2009, 09:06 AM
i checked the bar is pretty solid i am sure it is probably a combination of the lights themselves and the tabs
Old 06-06-2009, 09:12 AM
elblako91's Avatar
Heres an idea. Weld those suckers on there.
Old 06-07-2009, 12:05 AM
that wouldn't help. It's not a loose mount.
Old 06-07-2009, 05:26 AM
elblako91's Avatar
well if its not a loose mount and the bar is not loose the only other thing i could think of would be that the lens is loose in the housing. Might want to check that out.
-Blake
Old 06-07-2009, 07:04 AM
Belize Off Road Team's Avatar
what kind of lights do you have exactly? i know that companies such as Hella, PIAA and KC come with shock absorbing mounts to prevent vibration.
Old 06-07-2009, 08:18 AM
it's not anything loose. I believe it is a combination of the tabs flexing (like a diving board?) and maybe just low quality lights.
Old 06-08-2009, 05:53 PM
fireteacher's Avatar
ditch the bull bar. Get yourself an ARB or TJM. Otherwise, You will have to deal with it!
Old 06-10-2009, 07:54 PM
again, the bar isn't moving
ashersullivan88yota
01-18-2022 05:37 PM
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
v_man
07-23-2015 04:01 PM
Odin
07-15-2015 09:28 PM
Quick Reply: shaking lights on bullbar
