shackles
Old Oct 5, 2004 | 12:22 PM
Nathan Buchanan's Avatar
shackles
Well, I got some lift shackles, and now I can't get the darn old ones off. Surely I'm doing something wrong, but for the life of me I can't seem to get them off. I'm jacking the axle up, then letting the pickup down onto a jackstand under the bumper. The way I'm doing it is pretty redneck, but I figured it would work. Any ideas?
-Nathan
Old Oct 5, 2004 | 01:11 PM
89_4runner's Avatar
It doesn't take anything glamorous. You might need to remove the wheels and place a jack(s) and a jackstand under the axle to play with the amount of droop to let the force off the shackle bolts. It will also be easier if you can keep the axle relatively flat so the springs don't twist the shackles and add load to the shackle bolts. If that doesn't work use a BFH or rubber mallet to ease the bolts out.
Old Oct 5, 2004 | 01:44 PM
4Crawler's Avatar
I have some shackle installation instructions on-line. What problem are you having exactly?
Old Oct 5, 2004 | 06:58 PM
The bolts were frozen up pretty bad in the bushings. Ched (SloPoke) helped me and we got the darn things off. I need some new bushings now though, heh. Thanks Ched!
Old Oct 6, 2004 | 04:04 AM
SloPoke's Avatar
Anytime Nathan.
Big Little Bear
230
Nov 13, 2023 11:42 AM
Redeth005
Jun 28, 2018 08:16 PM
Scottcrb
Mar 3, 2016 11:57 AM
oldblue
Sep 28, 2015 04:07 PM
sonorn67
Sep 19, 2015 05:39 PM
