Sagging liftgate...
Old 04-16-2003, 10:38 AM
Beachrunner's Avatar
Sagging liftgate...
Does anyone know of a good aftermarket supplier of gas liftgate supports? Of course the OEM supports are outrageously expensive!
Old 04-16-2003, 10:48 AM
Co-Founder/Administrator
Staff
Corey's Avatar
Hi Daren, if you want factory, drop these guy's an email.
http://www.yotayard.com/
They might have a good set of factory ones in from a wreck, and be much cheaper than new.
Old 04-16-2003, 10:58 AM
rimpainter.com's Avatar
A trick I read in a mag once
Another trick is to use a small hose clamp on each black shock body. Sometimes this works, and sometimes it doesnt. Depends on how bad they are.
Old 04-16-2003, 11:15 AM
Corey, I thought about pulling some from a wrecked truck but I figured I'd be in the same shape I'm currently in. Does anyone know the life expectancy of those shocks? What causes them to fail? I feel certain I'm gonna end up banging my head on that hatch!
Old 04-16-2003, 11:31 AM
Firefyter-Emt's Avatar
vice grips.. Or drill shaft for a pin You could always use the old GM trick.. and cut a broom handle..
Old 04-16-2003, 04:54 PM
alanh's Avatar
Have you checked with your local autoparts store? The Schucks store I go to has some of those. Its anybody's guess if they have the right kind, but it might be worth a try. I don't have any experience with the quality, because I was looking for a light-weight one for a small pickup canopy and had to go to a canopy dealer to get that.
Blamalam
03-12-2022 07:34 AM
punks_is_4x4
05-31-2016 06:03 AM
89fourrunner
02-17-2016 06:52 AM
MichaelKLerner
10-27-2015 07:18 PM
Jake28296
09-03-2015 04:58 PM
Quick Reply: Sagging liftgate...
