Safety Cancel Switch
Yet another silly question from me. What is the safety cancel switch for? The guy who had the truck before me apparently disabled it. Seeing as I have no owners manual for it I have no clue.
Scratch the locker idea, people posted while i was typing.
Last edited by tombothetominator; 04-28-2004 at 08:47 PM. Reason: like three people posting at once.
Originally Posted by tombothetominator
??? What year vehicle? Are you talking about the 'clutch start cancel' button to the left of the steering wheel. If so it just makes it so that the clutch doesnt have to be in the start the truck. The only other thing that comes directly to mind is if you have the e-locker, and he disable the 5 mph engage and/or the 4wd required safties to turn the locker on?? Anybody else?
Yep thats the button. Thanks
I think you're referring to the "clutch start cancel" button. That button allows you to start the vehicle without pushing in the clutch when it is is neutral. Simply turn the key to accessories then hit the button put it in neutral then turn the key all the way, and it shoudl fire right up. Not sure if that's what you are talking about, but it's the only thing I can think of.
Originally Posted by Glenn
In neutral? What good does that do? That switch is for starting the truck in gear. If you are on a steep hill with the engine off, you can start up again smoothly without having to drop the clutch and floor the gas. It makes it so much easier to start uphill. No rolling backward, no bombing the clutch, no spinning the tires.
Originally Posted by superjoe83
but probably not the best on the starter though
kawazx636
10-06-2021 03:03 PM
83yotastockR
11
11-10-2015 06:54 AM
PNW94Runner
09-29-2015 02:55 PM
charlie_fong
09-27-2015 10:06 PM
