Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Rusted brake line section. Insitu repair without removing entire line?
#2 (permalink) |
Personal
Sales Rating: (0)
I think you are talking about the coolant lines that run to the rear heater. Those rust all the time in certain areas of the country.
If that's what you're talking about you can just bypass them and add rubber hose or bypass and block off and lose your rear heater if it's never used.
__________________
1996 SR5 4WD Auto Toytec Ultimate with OME 890's plus 10mm spacer 60028 OME shocks Treadwright Guard Dogs 265/75 -16 B&M 70268 with Magnefine filter |
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
Nope, unfortunately it is a hard steel brake line
#4 (permalink) |
Personal
Sales Rating: (0)
on my '94 i cut out a large chunk of the line, and added flares and fittings. it held up for a year and a half before I tore the truck apart.
#5 (permalink) |
Personal
Sales Rating: (0)
[OP]
YES! THANK YOU KBALL!
Upon further inspection it appears that these two lines on the passenger side ARE indeed the coolant lines going to the rear heater. I guess I must have lost my sense of direction the first time I was down here inspecting. The brake lines are on the drivers side, running right next to the fuel line. It's funny...these coolant lines are pretty much the same diameter as the brake lines. Im just going to spray some anti rust coating on these lines and call it a day
| Tags |
| brake, fix, gas, line, lines, repair, spaces, tank, tight, yotatech |
