rubbing noise when cold
Old 10-23-2007, 01:48 PM
shyogy's Avatar
i have a wierd noise when steering (right or left) - sound like something rubbing - usually just when cold but also if steering when going over a bump (speed bump) etc.
any ideas?
Old 10-23-2007, 01:52 PM
mikes19984x4's Avatar
are you talking about when the steering wheel is at what they call "full lock" - meaning it will turn no more in that direction, b/c on all vehicles you get that "rubbing noise" from the steering system. but check under and make sure nothing's caught under their such as sticks or even mud built up. saying this b/c i heard a rubbing noise one time, couldn't find it for a few days, and it turned out to be like a 3-inch stick...
Old 10-23-2007, 01:54 PM
shyogy's Avatar
not necessarily at full lock but it goes away after a few miles when it warms up
Old 10-23-2007, 01:56 PM
okay, so it does it when you 1st start the truck up? check your power-steering fluid level, as sometimes if it's low, you'll get some noise from the pump...
Old 10-23-2007, 02:02 PM
shyogy's Avatar
will do... thanks
Old 10-23-2007, 02:05 PM
no problem at all. and let us know if if that was the problem, or if it's something else. hopefully this is it.
Kreedy1
09-08-2015 06:33 PM
calderp
07-27-2015 09:58 AM
kvanzandt1
07-18-2015 10:15 AM
MTLroadierunner
07-15-2015 12:58 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: rubbing noise when cold
