Rubbing noise from front end
Old 05-30-2007, 07:48 PM
Crazychopstick's Avatar
Thought I'd update on this issue:
I recently installed new tierod ends and new lower balljoints on both sides of the Runner. The "rubbing" sound has died down a bit but it still comes and goes on occasion, just barely.
Old 07-27-2007, 06:55 AM
CBDenver's Avatar
Did all or any of the rest of you guys find anything that was causing this? I've got same thing and have been going thru the same list as everyone trying to figure it out.
thanks for the help.
Chris
1997 4-Runner 3.4L 4WD
Old 08-02-2007, 09:12 PM
The last modification I did was poly steering rack bushings. After that the "rubbing" could clearly be narrowed down to high-speed right curves only.
I'm pretty much set that it's a bad front passenger bearing, but I'm riding it out for now.
Old 08-02-2007, 09:39 PM
d0ubledown's Avatar
if it was louder on right sweepers than straight or left hand turns, then its a drivers side bearing..not PS.
Old 08-05-2007, 09:04 PM
  #25
Right curves. As in the truck is following a road that is curving to teh right.
I figured that with the weight off the passenger side is when the bearings can freely "rub" or grind.
And it's not louder. The noise is ONLY present on those curves.
MTLroadierunner
07-15-2015 12:58 PM
razorman8669
07-12-2015 12:13 PM
mlavery85
07-12-2015 10:33 AM
Jonny246
07-12-2015 04:51 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Rubbing noise from front end
