Replaced timing belt,marks were perfect,but not now
Old 02-16-2006, 07:30 PM
jimtanner's Avatar
Post Replaced timing belt,marks were perfect,but not now
Installed new belt,tensioner,seals,water pump.Had crank and cams lined up on the marks but now they are off a little and getting a tapping noise.Why are the cam marks off a little? Doesn't the crank mark set on the 0 mark at TDC??? NEED HELP THANKS
Old 02-17-2006, 04:08 AM
MTL_4runner's Avatar
Jim, just a suggestion, but I noticed you have a continuation of the same topic in 4 threads and it is usually easier to just have one thread and continue with asking questions/diagnosis in that one since it gets confusing to have the same topic for your truck discussed in multiple threads. That way if someone else comes along and wants to learn from what you went through there is a logical progression of diagnosis and repair hopefully leading to a fix at the end.
https://www.yotatech.com/forums/showthread.php?t=78968
https://www.yotatech.com/forums/f2/timing-belt-broke-tapping-noise-now-1998-tacoma-v6-78947/
https://www.yotatech.com/forums/f2/tapping-noise-1998-tacoma-v6-78911/
https://www.yotatech.com/forums/f2/timing-belt-check-change-1998-tacoma-v6-78806/
You might just copy your question into your first thread and delete the others. No, need to worry, I guarantee you'll get answered on YT (you can always bump your thread......by posting..... to the top if you want to).
Maybe a moderator can help you combine this all into one thread.
Old 02-17-2006, 04:21 AM
I found this in a search too:
https://www.yotatech.com/forums/f2/timing-belt-replacement-3-4l-40560/
voiddweller
19
05-02-2016 09:10 PM
vasinvictor
01-20-2016 12:39 PM
layifioren
10
07-06-2015 02:26 PM
marcusSRG
06-27-2015 07:13 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: Replaced timing belt,marks were perfect,but not now
