Replaced Head Gasket, but not Head Bolts -- How bad is this? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-09-2004, 10:46 AM   #1 (permalink)
The Rusty Gear's Avatar
Like it says, I had the HG done, but the bolts were not replaced. From what I've heard, this is common. If the bolts were torqued properly, this means that I should be fine ie under normal driving I should not blow the gasket again for another 160k?
__________________
1988 4Runner, V6 Auto, Mostly Stock
Toyota E-Locker Rear
32 X 9.5 Swampers
The Rusty Gear is offline
Old 09-09-2004, 11:43 AM   #2 (permalink)
roger's Avatar
I personally wouldn't recommend it, but it seems as though a lot of people have gotten away with it. IMO why risk having to do it all over again to save a few bucks on new bolts?
Anyway, just make sure you retorque them when the time comes (usually 500-1k miles).
roger is offline
Old 09-09-2004, 12:49 PM   #3 (permalink)
TRunner's Avatar
Quote:
I did not replace them on the full rebuild, but I did make sure they went back to the same location. From what the haynes repair manual claimed, you shouldn't replace them. I asked a mechanic about this and he said the same thing because the the threads already work together fine so why risk putting in a different thread? Seemed logical enough for me.
__________________
Ted
2007 Toyota FJCruiser
Model - 4704 4x4 SUV
TRunner is offline
Old 09-09-2004, 03:12 PM   #4 (permalink)
nfenwick's Avatar
Send a message via AIM to nfenwick
From what I understand Toyota does not advise reusing the head bolts. According to what I was told by Toyota the their bolts stretch when they are torqued down and should not be reused. Again this was what I was told by the Toyota Tech that did my head gasket recall work.
nfenwick is offline
Old 09-09-2004, 05:50 PM   #5 (permalink)
SoCal4Running's Avatar
The bolts are Torque to yield, basically when you torque a bolt you are actually stretching it alittle. A torque to yield bolt will only stretch once with a reliable and consistant reading on the torque wrench. They should not be reused although I have seen it done before on motors with no problems.
__________________
'86 4runner
22RE, 5-speed, LC Street EFI head w/ cam, LC Pistons, ARP Head Studs, Downey header, Dynomax 2 1/4" full exhaust, VDO water temp guage, 01-03 Tacoma cd\tape radio with 10" Bazzoka, Downey 2" rear springs, GDI radiator, Torus fan DONE!!!!
'68 Ford Mustang Fastback
Daily driver with a built 289 and a streetfighter trans.(Retired)
98 Subaru Outback-Took over daily driving duties
MicroMatic.com
Waco93.com
SoCal4Running is offline
Old 09-09-2004, 07:28 PM   #6 (permalink)
runnerboy97's Avatar
Send a message via AIM to runnerboy97
wow, this is a good thread. i just got in from working on my 3.0, i am replacing the heads cause one was cracked. i got one of the new heads on using the old bolts, but i didnt put them back in the same holes they were previously in. i think after raeading this i am going to go get new head bolts. my question is, will i be able to reuse the new head gasket i just put on, but have already compressed? or do i need to get another gasket for that side.
__________________
1997 4runner,lifted, locked, dash and grille mounted red LED lights, its my DD
1988 4runner, SAS, dual lockers, dual cases, longfields, 36's, and lots more.
runnerboy97 is offline
Old 09-09-2004, 09:16 PM   #7 (permalink)
superjoe83's Avatar
Send a message via AIM to superjoe83
Quote:
get the loosening sequence, and replace one at a time, this way shouldn't hurt anything
__________________
- Joe
1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks
1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs
superjoe83 is offline
Old 09-10-2004, 04:17 AM   #8 (permalink)
good idea, the reason i definatly want to replace the bolts is casue this truck appears to have had the heads off at least once before, as they were not factory head gaskets on there.
__________________
Old 09-10-2004, 05:39 AM   #9 (permalink)
SLC Punk's Avatar
Send a message via AIM to SLC Punk Send a message via MSN to SLC Punk
I have never re-used head bolts. I just talked to my friend, who is a ford mechanic and he said that he just replaces the gasket (not the bolts) and it is fine. He has done this on his 12 sec DSM, Turbo Miata and his old supercharged 5.0 Mustang. None of them had any problems.
When I got the HG replaced on my Celica at the dealership, I asked if they were going to put in new HG bolts, they said no. It made me feel uneasy, especially on a F/I engine, so I bought ARP head studs and had them install those instead.
__________________
-Travis
1997 4Runner SR5 V6 4X4 Supercharged Desert Dune SOLD :(
1992 Celica All Trac (AWD-Turbo) #223 of 271 US spec for 1992 FOR SALE
2005 Tundra Double Cab Limited 4X4 2.5" lift 265/70R17 Dueler Revo's
4Runner and Celica Webpage
SLC Punk is offline
Old 09-10-2004, 01:02 PM   #10 (permalink)
roger's Avatar
Having rebuilt a few motors in my garage, I always thought replacing the head bolts was standard operating procedure. I just assumed everybody did it as a matter of course. But I'm no crack mechanic either.
I would still do it, no matter what someone else told me. Like I said, why risk it?
roger is offline
Old 09-12-2004, 06:02 PM   #11 (permalink)
Dont you always use a tap clean and restore the threads in the block? If there is debris in the threads or burs to hang up on you will never get a proper torque reading on the bolts and they might not actually be tight.
__________________
'86 4runner
MicroMatic.com
Waco93.com
Old 09-12-2004, 06:54 PM   #12 (permalink)
geez those are some expensive bolts, i asked my mechanic buddy and they are $90. that is after he cuts me a break. i dont even want to know what the dealership charges for a new set of head bolts.
__________________
Old 09-13-2004, 05:26 AM   #13 (permalink)
$170.00 -I just ordered a set .But he gave me a discount b/c i spent over $900 on parts from them.(got 'em for $120)
HondaTec521 is offline
Old 09-13-2004, 07:37 AM   #14 (permalink)
TRunner's Avatar
Quote:
As stated in the haynes manual:
Tap and chase all threads and then hit with compressed air (always wear safety glasses) or a vacuum.
I can't tell you how many times I read that, but yeah I would highly suggest doing that.
__________________
Ted
TRunner is offline
Old 09-13-2004, 08:03 AM   #15 (permalink)
A whole lot cheaper than having to redo the headgasket.
Speaking of "A whole"s, the "a whole" mechanic that did the first headgasket on my '85 4Runner (note the word FIRST) thought there was a problem with the studs on my LCE motor that caused some problems. So, being an idiot I bought a set of bolts to replace the studs before contacting the company. The ARP studs were fine. The mechanic was wrong, twice. First he was wrong that there was something was wrong with the studs, next he was wrong when he torqued the studs to bolt specs. That headgasket lasted less than 50 miles and cost me another headgasket
Anyway, I wound up with an unused set of bolts that fit '85-95 22re. I did a quick check and they weigh in around 3 1/12 to 4lbs in the box and shipping to you would be $7.20 first class or $9.45 priority mail. LMK if you want them and you can have them for $50 and shipping. That should leave you enough $ for some pizza and beer while you put them in.
A one-time offer to a fellow Yotatecher in mild distress
Fahrenheit 451 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
how to determine if head gasket was replaced photoleif 86-95 Trucks & 4Runners 9 04-09-2008 04:25 PM
Help! Engine lopes after Head Gasket replaced. rwade 84-85 Trucks & 4Runners 7 04-19-2007 11:58 AM
ok replaced head gasket still oil in radiator( help please) dougm395 86-95 Trucks & 4Runners 2 10-27-2006 08:31 AM
purchase head gasket and bolts rose 86-95 Trucks & 4Runners 2 10-08-2006 12:43 PM
Just replaced timing set, head, and every gasket in the motor and have oil in water.. ovrrdrive 86-95 Trucks & 4Runners 29 06-17-2006 05:59 PM
2009 InternetBrands, Inc.
