replace rear diff. or entire rear end? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-23-2007, 12:18 PM   #1 (permalink)
washington4Runner's Avatar
question for the group: apparently my rear differential is bad - metal shavings and water inside - so should i replace just the 3rd member (i assume this is just the rear diff.?) for $275 plus $225 labor, or the entire rear-end for $550 plus $250 labor?
any help would be much appreciated since i only know how to drive 4runners, not work on them!
thanks!
washington4Runner is offline
Old 02-23-2007, 12:32 PM   #2 (permalink)
MudHippy's Avatar
Shoot I'll teach ya! Hard call for me to make without knowing the possible damage caused to the axle shafts or other internals, that occurs when the corrosive combo of water n' oil get together for a night on the town. Where the heck are ya I'll do it for less, kidding, though I would really, that's not very steep a charge as far as I've seen. Either way you need to go.
MudHippy is offline
Old 02-23-2007, 12:33 PM   #3 (permalink)
Staff
UKMyers's Avatar
Send a message via AIM to UKMyers
It depends on what grenaded. If it was just your ring and pinion just find a set of gears and an install kit and have somebody replace them. I just mailed a guy a set of 4.30 gears I had laying around for $20. I'm having a full third set up with a locker right now for $100. If one of your axle shafts came apart that's a different story. $225 in labor to replace a third is kind of steep unless that includes setting up new gears in it.
BTW welcome to Yotatech. Please take a few minutes and goto your User CP and fill in your location and put something in your sig line e.g. 94 4-Runner SR5 3.0L 5speed
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint
1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up http://www.yotatech.com/showthread.php?t=104000
Need Toyota Parts? www.davezoffroadperformance.com
Quote:
...why does my IFS have no flex, and what can I do to make it flex???
UKMyers is offline
Old 02-23-2007, 12:35 PM   #4 (permalink)
mt_goat's Avatar
How long has water been in there? You may get away with just replacing or rebuilding the 3rd member and maybe the axle bearings.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 02-23-2007, 12:45 PM   #5 (permalink)
thanks for the responses. hard to say how long the water and metal shavings have been in there. i just started hearing this kind of humming, growling sort of sound out of the back end, so i brought up to the shop where i always get my tires and had them look at it. they opened it up and said there was water and metal in there and that i need to replace the diff.
i grew up working on muscle cars, mustangs, etc., so i am relatively clueless when it comes to 4runners.
Old 02-23-2007, 12:49 PM   #6 (permalink)
Staff
UKMyers's Avatar
Sounds like your R&P is probably toasted. If you can afford it this a great opportunity to buy a drop in third with a locker installed from Trail Gear. They are a bit spendy though. Next time around install a diff breather hose that keeps it out of the water and change your fluids from time to time. If you have a stock diff breather and go through water over about halfway up your rim your gonna get water in the diff.
__________________
UKMyers is offline
Old 02-23-2007, 01:00 PM   #7 (permalink)
by r&p i assume you mean rings and pinions? since i don't do a lot of rock crawling, i am not sure i need anything too fancy. mostly use 4x4 for climbing dirt and sand when i am at the ocean looking for new surf spots.
so if i just need rings and pinions, i should probably just pick up the 3rd member, right?
__________________
2000 Black SR5 3.4LV6
- 265/75/16 Destination A/Ts
- Running Boards
- Front/Rear/Sunroof Spoilers
- Factory Rear Tint/15% Front Tint
- Debadged
Old 02-23-2007, 01:15 PM   #8 (permalink)
MudHippy's Avatar
Darn close, it means ring&pinion gears(2 total), however the differential has pinion gears also, 2 or 4. Yes, a third member swap is real easy, if you are familiar with RTV and bleeding brakes. An entire axle swap is more work but not much more complicated.
MudHippy is offline
Old 02-23-2007, 01:18 PM   #9 (permalink)
ok, i think i am starting to understand all of this. thanks for listening to all the newb questions.
__________________
- Running Boards
- Debadged
Old 02-23-2007, 01:20 PM   #10 (permalink)
Staff
UKMyers's Avatar
The Ring and Pinion is inside the third member. The third member itself it just the metal piece that the driveline hooks too and bolts to the axle housing. You dont' need a whole new third just the goodies that are inside of it. The easiest fix would be to pull a complete third with the same gear ratio out of one from the junkyard or somewhere. It's easy to change one out when everything is already ready to run.
__________________
UKMyers is offline
Old 02-23-2007, 01:23 PM   #11 (permalink)
aha, ok. so when someone says they have a 3rd member for sale for $275, you think they probably just mean the housing, not the goodies?
__________________
- Running Boards
- Debadged
Old 02-23-2007, 01:30 PM   #12 (permalink)
MudHippy's Avatar
Indeed it's possible that all you need is a ring & pinion, which isn't that much more difficult than either option, and could be the least expensive. Lot's of info from guys on this site or elsewhere available for free. I taught my self and I'm a slow learner, just be sure to have a good understanding, to save yourself the time/money/hassle of mistakes, over-sights,etc.
MudHippy is offline
Old 02-23-2007, 01:32 PM   #13 (permalink)
MudHippy's Avatar
No, sorry was typing, they probably mean the whole unit, most specify whether the ring or pinion and/or what ratio, is included. If they don't, assume it isn't included, no geussing on the gear ratio, a need-to-know in these circumstances. That's way to spendy for a third with no r&p.
MudHippy is offline
Old 02-23-2007, 02:01 PM   #14 (permalink)
Staff
UKMyers's Avatar
Ya just a third housing usually goes for $100-$150 bucks.
__________________
UKMyers is offline
Old 02-23-2007, 02:20 PM   #15 (permalink)
KyleT's Avatar
i have a good non-elocked third with 4.10s that came out of my truck. no noise and no teeth damaged. 157k on it when I pulled it. Its easy to do the swap. we did my e-lock swap in an evening and that imcluded cutting and tapping the new studs in the housing.
__________________
- Kyle
Former Owner of -
1996 Sunfire Red Metallic 4Runner Limited updated 10/31/06
OEM/TRD Lift Kit #1 from Sonoran Steel with 1 Top-out spacer - Lexus GX470 rims - 295/70r17 Nitto Terra Grapplers Yukon 4.88's, E-Locked Rear, Waiting to blow up front diff #2
KyleT is offline
Old 02-24-2007, 11:10 PM   #16 (permalink)
DarylD's Avatar
PM sent
__________________
94 4runner 4cyl 5sp, SAS , rear leaf swap ,Fj 80 front axle ,E-lockers
72 Datsun 510 2dr , v6 conversion in progress
DarylD is offline
Old 02-24-2007, 11:19 PM   #17 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
PM sent!
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
entire rear end for 92 2wd 22r small cab short bed 2wd1stgen The Classifieds GraveYard 4 04-17-2007 06:59 PM
replace rear diff or rear axle... in a bind old 86 86-95 Trucks & 4Runners 6 11-11-2006 10:20 AM
Best place to buy a good used entire rear axle Ilovemountains 86-95 Trucks & 4Runners 4 10-03-2006 08:57 PM
Will a 97 4x4 rear diff fit a 1997 2wd rear? blown2wdtoy 95.5-2004 Tacomas & 96-2002 4Runners 10 09-22-2004 01:40 PM
Rear ABS - sensor on rear end housing? sarasota4runner 95.5-2004 Tacomas & 96-2002 4Runners 3 06-18-2004 09:25 AM
2009 InternetBrands, Inc.
