Removing a 3" body lift?
Old 02-18-2005, 07:57 PM
m715's Avatar
I might be purchasing an '85 extra cab on Monday that has a 3" body lift. I live in Utah and I think anything over an 1" of body lift is illegal. I have always used suspension lifts and have never delt with lifting the body. Is it alot of work to remove the body lift and return it to stock.
Thanks for the info
Old 02-18-2005, 08:35 PM
4Crawler's Avatar
Usually not a problem, depending on how the lift was installed. Assuming parts were not cut and welded, it should be a simple matter to lower or remove the lift altogether. I have supplied parts kits for folks doing this very thing:
http://www.4Crawler.com/4x4/ForSale/...it.shtml#FAQ11
Old 02-19-2005, 07:59 PM
m715's Avatar
Thanks for the info. The body kits I"ve seen looked to consist 10 bushings, bolts and some sort of steering shaft extender, but I'm sure not all kits are the same. Nice avatar, looks like a pic of the Golden Crack on the Golden Spike Trail.
Old 02-20-2005, 07:38 AM
RED 85's Avatar
Hey what are you going to do with the 3" BL? I'll take it if you are going to just throw it away. I can pay for shipping.
Old 02-24-2005, 01:54 PM
m715's Avatar
RED 85,
I'm going to put the 3" b.l. on my '85 rock crawler.
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
Backcountry411
07-24-2015 08:06 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Removing a 3" body lift?
