Recommendations for cold air intake?
Our intakes aslo don't wail like some of the other imports do when removing the silencers or opening up the intake. I think it's more noticeable to the driver than others around you.
You want to hear loud then remove the silencer on a Honda;we removed the one on my friend's Integra Type R and it was just a tad louder before the VTEC kicked over then it was pretty obnoxious.
Our 4Runners sound nothing like that or even close when the intake is opened up.
1 degree is probably within the margin of error of the temperature sensor itself
The volume of the intake under the hood is about 1 cu^ft. Even at low RPMs, that 1cu^ft will be replaced by fresh air every second. Get the RPMs up and air will be replaced 10+ times a second.
It's just like trying to heat up a room in the winter with the windows open (and on a very windy day). Not gonna work.
