View Poll Results: What should I do to the engine?
Rebuild the 22R
16.67%
Replace 22R with a new(er) 22R
0%
Replace 22R with a 22RE
33.33%
Don't fix it if it ain't broke, replace water pump and timing belt
50.00%
Voters: 6. You may not vote on this poll
Rebuild or replace 22R?
Old 03-03-2003, 09:58 AM
Los Gatos?'s Avatar
22R has 200,212 miles on it. It runs and starts and everything just fine, I have yet to run a compression test or anything like that. However, if I'm going to rebuild or replace, now is definitely the time to do it (the title is in the mail, won't be here for a month thanks to stoopid PENNDOT) so what should I do? Replace it with a new 22R or 22RE, or rebuild it (new gaskets, water pump, metal backed timing belt, plugs ...all that kinda stuff)
Old 03-03-2003, 10:10 AM
HaveBlue's Avatar
I voted for the replacement. Here's why:
The fuel injected engine will give you a little more power and slightly better economy. It will also perform better off-road. You can go up or down some extreme angles without having to worry about a starving or flooding carb.
Another thing to consider:
I saw a post a little while ago about the interchangeability of the 3RZ 2.7L Tacoma engine with the 22R. If I remember, the transmission is either a direct bolt-on or, at the very least, the bell housing would have to be swapped.
Just my 2 senses
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
jerusry
10-19-2015 05:28 PM
87blyota
07-10-2015 04:31 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Rebuild or replace 22R?
