Rear window wiper blade replacement - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-19-2007, 05:28 PM   #1 (permalink)
Staff
rocket's Avatar
A couple weeks ago i went everywhere trying to find a rear window wiper blade but had no luck. After a YT search, i found a few recommendations to get an OEM replacement blade at the stealership. Next day i bought one and put it on in the parking lot.
It's the biggest piece of crap plastic blade ever. It was worse than my old worn out blade. It barely touched the window in 3 or 4 spots. I tried fliping it and tweaking the wiper housing but that didn't help. Total waste of money.
So then i bought a cheap "refill" at Walmart just find out that it's too wide and wont fit.
Today, i noticed that both front wiper housings were the same width as the rear. I always use Michelin windshield wipers which are great. So i bought one (about $7) and took it apart. The wiper itself has 2 metal inserts on each side. I cut the wiper with scissors and snipped the metal inserts with wire cutters. It fits perfect and works like a charm.
__________________
'96-'02
gone: '92
rocket is offline
Old 02-19-2007, 05:29 PM   #2 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
pics ? i dont use mine at all if that matters
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 02-19-2007, 05:37 PM   #3 (permalink)
drunberg's Avatar
I will have to try that. With all of the mag chloride on the road the past couple of months, my blade is pretty shot.
__________________
89 P/U: 295K Bought 06-92 Traded in 6-07
01 4Runner SR5: 101K Bought 02-06
Deckplate mod, True Flow Air Filter, 55/100W Headlight bulbs, Thule rack, Fog Light mod
My other toy:
Trebuchet with a 24' arm and app 3000lbs of pull from garage door springs. Will throw a 8lb pumpkin 1090'
05 Saab 9-2x Aero "It's a Saabaru"
drunberg is offline
Old 02-19-2007, 05:43 PM   #4 (permalink)
gpcollen1's Avatar
Yeah - a good cleaning at the gas station on fillups is usually all i need.
Did you get that little spring clip think with yours at the dealer. Without it, the blade sucks. The OEM replacement should be the way to go - and at 7 bucks it isnt even a rip off.
__________________
'99 SR5 Sport - Desert Dune: AirRaid MIT, OEM Air Filter, Toyo 265/75/16 ATs, Deckplate, PP Springs and Bilsteins, Cheapo nerf bars, Injector replacement impending
gpcollen1 is offline
Old 02-19-2007, 05:56 PM   #5 (permalink)
Staff
rocket's Avatar
Quote:
It was an OEM refill/replacement that was made of plastic and rubber...it didn't have any metal or a spring clip. That was all they had and all i needed.
For the same price i got a 16" or 17" Michelin blade and made it work. It was 100 times better.
__________________
'96-'02
gone: '92
rocket is offline
Old 02-19-2007, 06:16 PM   #6 (permalink)
gpcollen1's Avatar
Is it a refill or replacement??
Maybe ours sre different but when you replace it, you have to remove the two screws on the 99. In between the wiper arm and the blade assembly is a metal piece that acts like a little spring for the blade.
Is it just the size of the blad that makes it better?
__________________
Old 02-21-2007, 03:20 AM   #7 (permalink)
spage's Avatar
I need to replace mine badly even though I never use it. I bought my Runner used and I think the previous owner went a little crazy on the rear wiper usage. The blade's warn so bad that the little metal clip on the end drags on the window. There's now a large, half circle scratch in my rear door's glass
spage is offline
Tags
2003, 4runner, 92, back, blade, blades, insert, rear, removing, replace, replacement, replacing, saab, window, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
3rd Gen Wiper Blade Replacement Question... dgold General Vehicle Related Topics (Non Year Related) 3 05-20-2006 05:06 PM
New 2000 4R Rear Window Wiper Blade? jgs9455 95.5-2004 Tacomas & 96-2002 4Runners 10 01-07-2006 05:42 AM
2000 Runner Wiper Blade Size? 2000Runner 95.5-2004 Tacomas & 96-2002 4Runners 14 11-20-2005 10:37 PM
1995 rear wiper blade replacement "Cat-O-Leen" 95.5-2004 Tacomas & 96-2002 4Runners 1 06-20-2004 06:54 PM
Wiper Blade Replacement MonkeyElvis Maintenance & Repair Archives 13 08-04-2003 05:39 PM
2009 InternetBrands, Inc.
