Rear Recovery Gear
Corey here is page 2 of my snorkel write up there are 2 photos you can use there... Can I get that in a white & black missile, maybe an old Polaris?? Or I found this cool chrome one
If you're hooking up a tow strap you'll never, ever bend a pin. The shackle has an advantage is that you can simply attach a hook or snatch block, but you will NOT bend that pin. If you ever did, they'll not be hard to remove. You're strap will break before the pin will bend.
The amount of chafing you'll get on the strap is irrelevant. You'll tear it up somewhere else first.
XtraCab
04-12-2020 05:25 AM
jerusry
10-19-2015 05:28 PM
mengquis
07-13-2015 10:39 AM
Jnkml
07-06-2015 01:20 PM
