Rear axle seals - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-21-2007, 01:24 AM   #1 (permalink)
rgs20inophir's Avatar
Send a message via AIM to rgs20inophir
Rear axle seals
So I slid under the truck the other night only to find that my drivers side rear axle seal is pukeing all over the place and the right seal is beginning to go. How much of a pain is the job and are all of the SST's mentioned in the FSM necessary? Is it a day job?
I would kind-of like to have my truck ready to wheel by Labor Day and not have gear oil spewing onto my rear drums... something about axle grease and brake pads not getting along...
__________________
You only live once, make the most of it... lifes a trail, get out on it!
rgs20inophir is offline
Old 08-21-2007, 05:07 AM   #2 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Not a difficult job but that depends on your mechanic skills and tools.
Use the "search" feature and "rear axle seals" and you should find more than enough information.
waskillywabbit is offline
Old 08-21-2007, 05:33 AM   #3 (permalink)
cootees's Avatar
Send a message via AIM to cootees
Yeah, it's pretty easy. Getting them to seat properly is the worst part. Marlin has an axle seal with a lip on it that is suppose to ease that burden though.
__________________
-- '90 4Runner 2Dr
3.0 / sas /OME 860 coils / rear e-locker / 32's/ MC Rear bumper / TG Sliders / surco basket / cobra 18 wxstII / ISR / Magnaflow exhaust
cootees is offline
Old 08-21-2007, 06:35 AM   #4 (permalink)
mjwalfredo's Avatar
Send a message via AIM to mjwalfredo
Also be very careful not to damage the axle housing surface when removing the old seal. A big set of pliers worked well for me. Use a pair that allows you to get a good grip on the seal and yank it out. Also, those Marlin Crawler seals only work in axle housings on trucks without ABS. I was out of luck there
__________________
-Marcus
1997 4Runner Limited 4x4, E-Locker, Bilstein HDs, Air Springs, Deckplate Mod, 265/75/16R Bridgestone Deuler A/T Revo
mjwalfredo is offline
Old 08-22-2007, 08:36 AM   #5 (permalink)
Wazioc's Avatar
I just did mine a few weeks ago and I was actually surprised how easy it was. I went to napa and bought a seal puller, big spikey nasty lookin thing and it was kinda hard to used, but seemed to work ok. I had trouble reseating them too and even tried freezing. What worked best for me was to get it lined up the best I could then very carefully install the axle again and start tightening all the bolts this slowly and evenly seats it into place assuming everything is flush when you start cranking.
__________________
'97 5-spd 4Runner Deck plate, Diff breather, ISR mod, OME 891/N86 rear, Tundra/Tokico blue front
Wazioc is offline
Old 08-22-2007, 08:42 AM   #6 (permalink)
drew303's Avatar
there are two seals
theres an outer seal that fits into the bearing case then the axle and bearing get pressed in. You have to unpress the bearing and retainer to replace that seal. Then theres an innner axle seal that you can easily remove and replace once the backing plate/bearing case and axle are removed.
Then theres a third seal, its a large 0-ring that fits around the lip on the axle housing.
You need a SST to the bearings off ... its $200 to buy or about $40 an axle to have a shop do this work for you
Might as well replace the seals and bearings IMO.
__________________
1987 Pickup, single cab, 22R, new head, 260 cam
TG 3" SAS, rear disc brakes, chromoly rear axles, Chromoly Birfs, Tcase brake, 37x12.50R15 MT/Rs, 5.29 gears, rear Aussie Locker, front Detroit Truetrac.
drew303 is offline
Old 08-22-2007, 09:14 AM   #7 (permalink)
mjwalfredo's Avatar
I agree with Drew, I have had bad luck with leaking axle seals and everytime it has happened, the oil washed the grease out of the bearing and that's no good.
__________________
-Marcus
Old 08-22-2007, 10:18 AM   #8 (permalink)
mkgarrison5's Avatar
at how many miles on your truck are you seeing this rear axle seal leak?
mkgarrison5 is offline
Old 08-22-2007, 01:03 PM   #9 (permalink)
bratliff's Avatar
I just found mine are seeping this weekend.. not enough to show but when I pulled the drums off for a brake inspection the shoes were "wet" .. truck has 169,000...
bratliff is offline
Old 08-22-2007, 01:21 PM   #10 (permalink)
Quote:
just thought i had the same problem with a "seal" took out the axle and whoa the bearing was SHOT.... the axle moved in circles... pretty bad. and pretty damn expensive, the bearing alone was like $58 and people are telling me i got a deal on it... plus you have to have a press to remove the old bearing and they used some special tool to press it off. PITA. if you are lucky you can find a used axle with a bearing on it already (if you happen to have a bad bearing) then just slide it in. if not then good luck, its not cheap...
__________________
1990 toyota 3.0 v6 xtra cab sr5, 5 speed manual
hannemann tacoma front end conversion,
downey headers, turned down 2 1/2" exhaust
Centerforce dual friction clutch
3" body lift
4" suspension lift IFS
4.88 front and rear, lincoln locked
15x10 black rock crawlers w/35x12.50x15 BFG Mud T
Azusacanyonbogger is offline
Old 08-23-2007, 05:08 AM   #11 (permalink)
bratliff's Avatar
Quote:
that was the first thing I checked I pushed in all directions on the axle its tight.. I think its just the seal.. now I just have to find time to fix it...
bratliff is offline
Old 08-23-2007, 05:24 AM   #12 (permalink)
rearviewmirror's Avatar
Send a message via AIM to rearviewmirror Send a message via MSN to rearviewmirror Send a message via Yahoo to rearviewmirror
I just had mine replace under warranty. My 4Runner drives so much better now, no more "thump" when you try to drive forward after it had been sitting for a while.
__________________
2000 4Runner Limited 4WD
Millennium Silver
Toyota OEM NAV
OME springs/shocks F/R
VZN185L-GKPZKA 4.300 With P265/70R16
rearviewmirror is offline
Old 08-23-2007, 05:33 AM   #13 (permalink)
Quote:
thump?? out of curiosity how does that make it thump? i get the "thump" when i stop at a stop light and when i take off i get a thump occasionally on a fast brake at the light. i can tell a difference when i grease my driveshaft it will stop for a long while.
Old 08-23-2007, 11:25 AM   #14 (permalink)
mjwalfredo's Avatar
Azusacanyonbogger, are saying that your seal was fine but the bearing was not and the axle was moving around so much that oil was leaking passed it?
__________________
-Marcus
Old 08-23-2007, 12:13 PM   #15 (permalink)
RunnerUp's Avatar
this is a really easy thing to fix on the 3rd gen 4runners... here is a link to my write up of it, and the first part to get you an idea of what is involved
http://www.yotatech.com/f2/replacing...s-pics-110243/
__________________
Kyle
2002 4Runner - Lifted/Locked/Armored/Charged - 145k Miles
2007 4Runner V8 Sport Edition 4WD 20k Miles
Buy My Stuff!!!
http://www.yotatech.com/f109/97-4run...rt-out-151470/
RunnerUp is offline
Old 08-23-2007, 12:14 PM   #16 (permalink)
RunnerUp's Avatar
and as long as you can find a machine shop to press off and on the bearings then yes, its a day job
__________________
Kyle
Buy My Stuff!!!
RunnerUp is offline
Old 08-23-2007, 01:27 PM   #17 (permalink)
Quote:
i changed everything once i was in there since i already bought it but the seal looked okay. the bearing was just REALLY bad... leaked everywhere. maybe i couldnt hear it because of the tire noise but it was bad.. new bearing now and its good as new with no leaks..
__________________
3" body lift
Old 08-23-2007, 01:31 PM   #18 (permalink)
its easy if you take it to a machine shop to have them press it. i was talking about doing it yourself on a press. not easy... had to borrow a tool from a toyota dealer mechanic and use it on my press.. didnt want to ruin that expensive ass bearing by forcing it in!
__________________
3" body lift
Old 08-23-2007, 02:51 PM   #19 (permalink)
Some info here... <---- this is a link
poser is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
rear axle seals tyndalltoy 86-95 Trucks & 4Runners 11 02-11-2007 08:48 PM
Leaking rear axle seals!!? stangman39 95.5-2004 Tacomas & 96-2002 4Runners 10 08-31-2006 08:23 AM
rear axle seals and bearings. jonwanner 95.5-2004 Tacomas & 96-2002 4Runners 4 06-01-2006 10:55 PM
Blowing Right rear Axle Seals??? T-A-Z-M-A-N 95.5-2004 Tacomas & 96-2002 4Runners 13 02-04-2005 11:26 AM
Need help with rear axle seals David 95.5-2004 Tacomas & 96-2002 4Runners 36 09-09-2003 08:07 AM
2009 InternetBrands, Inc.
