quick help diff fluid question
Old Oct 30, 2004 | 09:29 AM
fiveofeen's Avatar
i am changing the fr/r diff fluid trans (man) and transfer case. i put 75w90 in the frt axle instead of 80w90 i'm using royal purple and this crap is exspensive. do i need to swap it out and get the 80w90? i didnt see any royal purple 80w90 gear oil. the truck is in the garage right now waiting for me to make up my mind. can anyone get me quick answer?
Old Oct 30, 2004 | 09:45 AM
I've been using Amsoil Series 2000 75W/90 in front/rear diff, transfer case, & manual tranny for 6 years now. Shifts so much smoother - especially when the temp drops. Never a problem - yet. Don't worry - just keep feeding the runner the good fluids and they'll run forever.
Andrew
Old Oct 30, 2004 | 09:48 AM
fiveofeen's Avatar
yeah i'ma keep the 75w90 in there, hope it works out okay i'm sure it will. the 96 takes a couple different fluids than the 94. my manual says i should use dexcron atf II in the transfer case and 80w90 in the diff and 75w90 or 80w90 in the tranny , although i am positive anything is better than what was in there.
Old Oct 30, 2004 | 10:22 AM
4Crawler's Avatar
With gear lubes, the 2nd number (hot viscosity) is the most important. With xxW90, really makes no difference what the "xx" is, that is just the cold viscosity. Once the diff is up to temp, 75W90 is the same as 80W90 or even straight 90W.
jasonty
41
Dec 23, 2018 01:00 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
yourrealdad
Jul 21, 2015 11:13 AM
scottyg486
Jul 19, 2015 05:34 PM
icentropy
Jul 14, 2015 10:23 AM
