Power antenna
Old Aug 30, 2006 | 09:45 AM
darkglass's Avatar
Power antenna
Is there a specific fuse to ONLY disable the power antenna on my 98 runner? TIA
Old Aug 30, 2006 | 12:29 PM
Elton's Avatar
just remove the stereo and unplug it there will be a little box thats say Power antenna
Old Aug 30, 2006 | 07:04 PM
darkglass's Avatar
ah yes. However, I want to utilize the antenna... just not the power mechanism of it going up and down.
Old Aug 31, 2006 | 01:18 AM
rocket's Avatar
just break the gears. sooner or later it will happen naturally anyway.
At first, mine grinded like hell but still worked. Then it went up or down when it wanted to. A few days later it stayed stuck in the up position.
If you wanna buy it just let me know. lol
the 'Tacoma whip mod' is what you probably want to do.
Old Aug 31, 2006 | 05:09 AM
Ironmike4x4's Avatar
I just diconnected the blue wire to the power antenna and left it up. I can still listen to the radio, just not the grinding of the gears.
Old Aug 31, 2006 | 05:30 AM
Godzilla's Avatar
try throwing an inline switch on it. I did this for my 92's antenna. Just splice into the power wire for the antenna motor and run a switch in cab. Antenna up/down when you want. The great thing is that you still get good reception in the city with it down.
Old Aug 31, 2006 | 07:40 AM
Elton's Avatar
my antenna is broke so i unpluged it and pulled it up by hand works fine
Old Aug 31, 2006 | 09:27 AM
cackalak han's Avatar
I did that in my last car, because the antenna would go up everytime I ejected a CD, which would turn the radio on. So at every CD change, the antenna would go up half way, then when I put the CD in, it'd go down again. It got annoying, so I spliced in a switch, as well.
Old Aug 31, 2006 | 07:00 PM
darkglass's Avatar
I like this idea. No more winding motor everytime the radio/cd is turned on or off.
DeathCougar
Apr 1, 2018 11:29 PM
mussy01
Dec 13, 2016 08:20 PM
delmert
Sep 30, 2015 04:34 PM
Sidherish
Aug 2, 2015 01:42 PM
TDonkey
Jul 26, 2015 10:14 AM
