Options for Wiring a Rear Aux. Light??
Old Nov 17, 2004 | 05:32 AM
HuntRunner's Avatar
Hello all.....I am needing more light at the back of my truck, and need it to be operated by a switch. I already have 2 55 watt Hellas mounted on the front of my roof rack; can I just add a single (low wattage) light to the back and wire it to the existing lights? My current wiring is what came with the Hellas. Will this overload that set up and switch?
Any recomendations on a light to use? I need it as a work light and reverse light.
Old Nov 17, 2004 | 08:35 AM
Good Times's Avatar
just run another relay and switch that's separate from the existing wiring loom. it'll be easier to work with that way (i think)
Old Nov 17, 2004 | 06:09 PM
Corey's Avatar
Co-Founder/Administrator
Tractor lamps put out good light.
https://www.yotatech.com/~corey/tech...ghts/corey.htm
Old Nov 17, 2004 | 06:12 PM
Brendan's Avatar
Originally Posted by Corey
I concur.
Old Nov 17, 2004 | 06:22 PM
Ironmike4x4's Avatar
Obviously I didnt do to hot in electrical classes.... but I think you have to worry about the load from the other lights dont you?
Old Nov 17, 2004 | 07:09 PM
SoCal4Running's Avatar
Adding an aditional light MIGHT blow the reverse light fuse, or it might not. Only one way to find out.
I would wire a new relay and tap into the existing reverse light to turn on the relay. Dont forget to put a fuse in the power lead. Thats how mine works.
Jun 1, 2021 01:51 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
lledwod
Aug 30, 2016 01:03 PM
toyota32
Jul 6, 2015 05:42 PM
Vargntucson
Jul 4, 2015 12:15 PM
