oil pressure
oil pressure
i have a question i have an 84 toyota pickup with a 22re efi engine and the oil pressure is really low when ever you drive it. is that just a trait for an 84 toyota or does something need to be replaced i just wanted to make sure that there could be a chance its just a trait for that year of truck before i go spending money to replace something.
Oil pressure should be between 36-71 PSI @ 3,000 RPM.
At idle it's about 3-4 PSI.
As you can see low oil pressure while driving is a problem.
It's possible the oil pressure sensor is failing and providing incorrect info.
Suggest you replace the oil sensor.
Odin
07-15-2015 09:28 PM
88yodabasket
07-13-2015 01:32 PM
