OBD-I Codes
Old 08-20-2004, 11:03 AM
805specr's Avatar
OBD-I Codes
I have a 92' Pickup and I'm not familiar with OBD-I.
Is it possible for the computer to store codes/information without the check engine light coming?
Old 08-20-2004, 11:08 AM
nunsa's Avatar
Yes! The Check connector is under your hood next to your fuse box, grab a paperclip and put one end into the "t" or "te" terminal and the other end into the "e" or "e1", turn the key to on but do not start, a code will flash on the dash, if you have no codes, it will flash real fast, if you have a code, it will flash a 2 part code, example: code 21 would be ** followed by a short pause and then a *, and then the code would repeat itself or start another code!
Good Luck!
* Harry *
Old 09-11-2004, 03:22 PM
805specr's Avatar
Finally pulled the code!
I pulled code 14 which I think is a ignition signal problem. What could cause something like this and what should I check??
moparbay
10-06-2015 09:24 AM
bradahman
10-01-2015 09:24 AM
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
Draven023
09-26-2015 12:41 PM
Quick Reply: OBD-I Codes
