Not sitting level
Not sitting level
I just put on a 2in body lift yesterday on top of the 3in spacers up front and 891's in the back that i was already running and now it looks like my passenger side is a tiny bit higher than the drivers so i measured it and the front is off by 3/4inch and the back is off by just over half an inch. i checked all the body mounts and everything looks good all the spacers and bushings are in and tight. So im lost now anyone got anyideas as to what might be causing it?
no before and after pictures?
my guess is that your difference was there before the body lift and now it is just more noticeable.
-when you say the mounts are tight, did you torque them all to the same amount?
I have noticed too that vehicles that tend to only have a driver in them develop a slight DS lean with time.
i went to look at a car one time that had a noticeable lean...when the guy came out I understood why
i dont have a camera so no pictures and all the bolts are torqued down the same. I think it may have already been there before the body lift it just didnt stand out as much
Bourbonblues
12-15-2017 05:43 PM
justdifferentials
14
06-11-2017 08:36 PM
