| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Newbie having issues with an 89 pickup
#2 (permalink) |
Check the throttle cable and make sure it isn't adjusted too tight. That was my problem.
:bounce2:
__________________
"I'm your huckleberry." - Doc Holiday - '93 4runner - Sold! Current Ride - 2001 Chevrolet Silverado 1500 ext.cab, pewter, 5.3L, 3.42s, fully loaded, 68K miles. FREE ROCKET!!!! |
#3 (permalink) |
Yeah, I checked that , forgot to mention that, throttle cable isn't tight at all, and the tps I installed is adjusted properly, this thing is giving me fits, and I have no codes from the ecm. Last code I had was the knock sensor, but some genius before me had jammed the connector in the wrong way, so thats resolved. Wondering if the vacuum lines being all crossed up could have screwed something up. I'm grasping for straws here trying ot figure out why my idle is such a mess. Thanks for the suggestion though.
#4 (permalink) |
Did you pull the EFI fuse for 10 minutes and let the computer reset? If not, try that.
__________________
#5 (permalink) | |
Quote:
Good Luck! * Harry *
__________________
The Master Toyota Tech, 2003 Toyota Tacoma xtra-cab, 3.4 V6, 5speed,4x4, TRD w/OffRoad Package. "Expert on the 3.0 Engine!" Disclaimer: As a former TOYOTA TECHNICIAN I authorize this post/reply US MARINE*** SEMPER FI |
#6 (permalink) |
did you do the head yourself? recently i was looking at a 91 runner 4banger 5spd that idled high also. the guy tried all kinds of fixes to get it to idle properly, turns out the head gasket was folded over on the front cylinder. he replaced the hg and the idle came right to specs, after he reset everything from previously fiddling attempts. hope that helps.
lee |
#7 (permalink) |
Location: Bend, Oregon. 4mer Teufelhund, now a DoD Contractor
When my 90 SR5 V6 hit about 143k miles the exact same thing started happenning. I mean exact same thing!! (good description of the fault) I had it taken to several mechanics and after buckets of money and countless attempts to repair it my present mechanic arrived at the solution. He's a former dealer mechanic who went out on his own and knew exactly what the problem was right away. 4give the longwinded build up. The problem is your cold idle/start valve. I may have mispronounced that part name but those in the know will understand what I'm talking about. It is an expensive component that is integrated into a lager part of your intake manifold. I can only assume that they used a similar set up on the 4 cyl trucks as the 6 cyl trucks and runners. Well I can tell you that the new part from the dealer was in the neighborhood of $600. My guy found one at the salvage yard for like $100 or $150 and it fixed the problem right up. we'll see how long it holds out. 10k miles already. I can almost guarantee that's your problem Bro.
best of luck and welcome to the board.
__________________
90 4Runner SR5 V6 3.0 The Illness: Downey K&N Intake kit/ISR/Downey Headers/2 1/2" Custom Exhaust/Hi-flo Cat/Spintech Muffler/Flex-a-lite/NWOR 1 1/2" lift Springs & 26mm T-Bars/4.88's/32x11.50R15 A/T's/Aisin manual hubs/Genuine Steel Euro Guard, Step Bumpers & Taillight Guards/Weather Guard Visors & Deflectors/Bushwacker Flares/Stripes removed/TRD Decals/Euro wheelskin. |
#8 (permalink) |
Head was done before I got it, I did a exhaust gas check on the radiator and a pressure test, and nothing, head is fine. I'm gonna replace all the vacuum lines today, just for my benefit, but I have a feeling its that idle air valve...(hope it isn't,lol)
#9 (permalink) |
hey i would put my money on the idle valve ( i just call it the choke) i have an 89 22RE and it will idle hight once in a while so i just leave it but mine goes away so i would try that.
cody
__________________
89 Yota extra cab Black with Blue Pearl and Frenched Antena 2 inch BL with 31x10.5 BFG M/T's (winter) Bridgetsone Winter Duelers 31x10.5 I love these tires 2 Memphis HPO 10's MC1000 memphis amp (1100 RMS) 5 1/4" memphis door speakers, 2 memphis 6 1/2" 2 memphis tweets, 2 memphis 4 inch Premier DEH-750 deck Black widow alarm w/ power locks Euro Headlights (H4), Euro Tails, 2 inch exaust with 3 inch tip and Walker muffler, K&N Filter, MSD Wires, |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Newbie 88 4x4 pickup | wch2106 | 86-95 Trucks & 4Runners | 9 | 07-20-2007 11:56 AM |
| Got The 89 Yota Going, But Still Issues | YOTAKIMMER | 86-95 Trucks & 4Runners | 1 | 12-04-2006 04:25 PM |
| 4wd 85-89 pickup, or 4runner (or 90+pickup) | alexchannell | The Classifieds GraveYard | 2 | 11-04-2006 06:42 PM |
| starting issues 89 3.0 | shiftless89 | 86-95 Trucks & 4Runners | 0 | 07-17-2006 03:18 PM |
| newbie to toy pickup | letigre87 | Off Topic Talk | 2 | 06-13-2006 04:57 AM |
