mystery water leak
mystery water leak
i've got a 96 4runner 3.4 automatic 4x4. it leaks alot of water. as in i need to fill it up every day becuase the light comes on and it runs hotter than usual. ive looked everywhere for the leak and cant find any water except for the ac drip which i can see dripping from a nozzle on the fire wall. any suggestions are appreaciated.
Pressure test the cooling system. Running it hot like that will ruin the motor quickly or at least significantly impact it's lifespan. It could be going into the combustion chamber. Any running issues, lack of power, white smoke out the tail pipe, rough idle, etc..? The more details, the better we can help. Have you had the codes read yet?
Look around the oil cooler, water pump, and thermostat with an extendable mirror and a flashlight. You should see coolant trails or residue if it's leaking from any of those.
WellsR
12
07-31-2015 03:27 PM
Avenged
07-09-2015 07:55 AM
