Locker or limited slip. That is the question.
Old 07-22-2004, 01:19 PM
88yotaboy's Avatar
Im planning on a putting either an auto locker or a limited slip in my rear diff and dont realy know where to start as far as what works well and can still be used in a daily driver. Id like to go ARB but they are above my price range .
Thanks in advance,
Andy
Old 07-22-2004, 01:49 PM
mastacox's Avatar
Thanks in advance,
Andy
Search would be helpful :pat:
Detroit EZ-Locker only costs about $200 and is pretty easy to install if you have some technical ability, and a way to check backlash.
Old 07-22-2004, 02:53 PM
gwhayduke's Avatar
I'd go with a TruTrac up front and a Toyota electric locker in the rear. The banging of a mechanical locker as well as the odd handling when streets are slick are big negatives to me. Of course, if ya got the bucks, you can go with ARB at both ends.
Old 07-22-2004, 03:15 PM
88yotaboy's Avatar
I dont got the bucks for an ARB and i dont realy think i wanna mess around with trying to find a factory e-locker. So what are my best options for a rear locker or limited slip?
Thanks,
Andy
Old 07-22-2004, 03:41 PM
Flamedx4's Avatar
Depends on what you want to do with it. If it's really 95% street driven you might not want to live with a locker. And if you use 4wd on the street in the winter you really won't like anything up front but open diffs, which is why front ARBS are so nice. A truetrac in the rear, for instance, is durable, smooth, and quiet, yet really hooks up. Not that expensive either. Do some research, don't just wait for folks here to tell you how to spend your money... You might start here, there's good info well presented: http://www.reiderracing.com/rtech_diffs.htm
Old 07-23-2004, 09:43 AM
88yotaboy's Avatar
bump.
Old 07-23-2004, 10:03 AM
gwhayduke's Avatar
Can't search Gomer?
Cheap-Lockrite rear axle only
Expensive-True trac front or rear.
Never put a automatic locker in front dif.
Old 07-23-2004, 10:11 AM
Pretacopower's Avatar
I asked a similar question awhile back when trying to decide whether or not to get an automatic locker (Detroit EZ). The general consenus was that they are worth the drawbacks (i.e. the noises and adapting your driving skills). I haven't installed mine yet, so I can't give my full opinion.
I dont know if you have a manual or not but I've heard that auto-lockers are auto-tranny friendly.
Check out this site for a little more info.
http://www.jawsgear.com/positractions.asp
Old 07-25-2004, 06:50 PM
AKennedy87's Avatar
Will a toyota electric locker work in the rear of a 87 8" 4 cyl rear end?
Old 07-25-2004, 06:54 PM
doink's Avatar
perhaps im wrong, but i think some people do that if they have manual hubs....
Old 07-25-2004, 06:56 PM
gwhayduke's Avatar
Good catch...You're right.
Old 07-25-2004, 07:36 PM
dragr1's Avatar
Locker, get it and you'll know why. If you wheel a lot anyway, if it's totally street driven , which I'm assuming it's not, then get the limited slip. I debated this same thing about a year ago-I ended up with a Toyota e-locker and I do not regret it. Even with a full time rear locker, street abilities won't be affected that much once you get used to it.
TheBFA
02-15-2020 06:55 AM
primordialbeast117
12-19-2015 12:23 PM
Chicken12
10-14-2015 03:54 PM
Jdgarrison
10-01-2015 02:11 PM
charlie_fong
09-27-2015 10:06 PM
Quick Reply: Locker or limited slip. That is the question.
