Lets say a guy hasn't changed his oil in a while...
Old 12-18-2004, 01:33 PM
14thegipper's Avatar
Any way to make it right, like flush out the system???
Assume one would want to change oil and see what is in there, like maybe with a magnet/strainer??? Check for sludge???
Should the seafoam (fuel injector) cleaning be postponed or expidited???
Thanks...
Old 12-18-2004, 01:40 PM
96LtdYota's Avatar
umm.. how long is a while?
Old 12-18-2004, 02:25 PM
evilcow's Avatar
I would put the seafoam in the crankcase and see if that cleans it out.
Old 12-18-2004, 03:02 PM
How long is a while
2 plus years...
30k maybe 40k...
without oil change...
checked the dipstick today, had some oil on it...
Old 12-18-2004, 03:47 PM
Vato Loco's Avatar
Some?!?!?!?!?!?!?!?!?!?! Please tell me the vehicle was stored for all that time!
Old 12-18-2004, 03:59 PM
rearviewmirror's Avatar
Please post the VIN number so I can add it to my list of 4Runner's NOT to buy........
Old 12-18-2004, 04:07 PM
hre814's Avatar
did you just buy this 4runner or was it yours the entire time? if you just bought it, did you know the oil wasn't changed in that long of a time? i have no idea what may come out if anything at all.
Old 12-18-2004, 04:13 PM
Cardiac's Avatar
I have seen the inside of motors where the oil was never changed. The oil was no longer a liquid, it was solid sludge. It's the most horrible thing I had ever seen in a motor. You could not even see a rough outline of the head bolts. And I don't think that one was anywhere near 30 or 40k...
Old 12-18-2004, 04:14 PM
superjoe83's Avatar
personally, i would pull the pan and clean the pickup and the bottom of the pan, then change the oil and drive it for about 1000 miles and change it again, and from now on, change it at every 3000 miles to slowly break up any left over sludge, you don't want to clean it all at once
but this shows the durability of a Toyota engine
Old 12-18-2004, 04:18 PM
gwhayduke's Avatar
Yeah, ya ought flush it. But you probably should do what I do, a short change. Get some Mobil "Drive Clean" motor oil in 5w-30 or 10w-30 change the oil and the filter, then drive it a couple weeks to a month. Before you change it again get some Marvel Mystery Oil, Gunk Motor Flush (which I hate), or Amsoil motor flush, put it in and follow directions. Drain and refill with a good quality oil.
Ray Maliozzi (or was it Tom?) of Car Talk fame, tried running his Dodge Colt Vista wagon without changing oil for several years, just to see what would happen.
Nothing Happend.
He finally got weak when he had to get it inspected and let them change the oil. End of experiment. But the Colt is still running.
Old 12-18-2004, 04:43 PM
Yamaha+Toyota=Fun's Avatar
There was a 3.4 motor outa a taco on ebay a while back that never had an oil change and the motor was almost completely destroyed. The cam bearing spun, rod bearing spun, pistons, crank, con rods, oil pump was bad, etc. all totally destroyed. This was after like 60k miles though on the original oil. I guess the motor still started up when they pulled it. Those are somethings that could go wrong if you dont change your oil.
Old 12-18-2004, 04:52 PM
Arnold's Avatar
I was thinking the same thing.
Old 12-18-2004, 05:24 PM
Ironmike4x4's Avatar
You'd better clean it real good and pray that the rods dont decide to do the "twist" or worse.
Old 12-18-2004, 06:21 PM
Thanks guys, I guess I will do a short change, see how that goes....
I'll post sme pictures if someone wants to tell me what to look for.
I will say that I pulled the cap and it looked quite clean...
pathetic huh?
Old 12-18-2004, 06:32 PM
waskillywabbit's Avatar
Toyota engineering conquering Darwin in action here.
Old 12-18-2004, 07:17 PM
yotaluver's Avatar
did u check it at all in the last 2 years? if not it is nice that it still has any.
Old 12-18-2004, 07:40 PM
NorCalVP's Avatar
Thanks...
My 84 Tercel goes about 10K between changes. But then again it burns a quart every 1000 miles anyway...
Old 12-19-2004, 04:47 AM
Paul H.'s Avatar
the dealer and most shop can do a complete engine flush. you may want to check into that.
Old 12-19-2004, 08:53 AM
Engine flush sounds like the ticket.
Will let all know what develops...
bigjstang
08-25-2021 12:41 AM
Yota.Jay
07-23-2015 08:08 PM
skoti89
07-08-2015 12:05 AM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Lets say a guy hasn't changed his oil in a while...
