Kill Switch...
#41
The last thread that went though this I THINK spec'd the stock fuel pump at around 17amps. That's a lot of current for running wires into the cab (think "will generate heat on long trips"). A 30amp relay is about $8-9, and then you could even use a small mini toggle, or a reed (and a latching relay) or ....
#42
Location: Houston (home), Atlanta (school), Cincinnati (work)
theBAYsic
09-16-2015 05:21 AM
