It's cold in them thar' hills..
Old 12-03-2004, 01:16 PM
yotafreakshow's Avatar
Heater issues, 22re
The heater barely works in my 85 4runner. Just barely defrosts the windshield after 15 minutes of highway driving. It was 0 degrees F this morning, I am still thawing from my drive to work. I put in a new thermostat (with 1/8" hole), checked that the heater hoses were in the right places, (they weren't), still didn't fix it. Seems like there is restricted flow into the core, but I pulled the hoses and pushed water through it both ways pretty easily. Any ideas anyone?
22RE. Headgasket is new. Engine runs at normal temps. I don't have a diagram of the 2 coolant hoses that attatch to the pipe from the back of the water pump, under the the TB. If anyone has a pic of that so I can can make sure they are all in the right spots I'd love to see it. All of the vacuum lines were messed up from a previous owner, so I wouldn't be suprised to see anything.
Old 12-04-2004, 06:47 AM
bump.
Old 12-04-2004, 07:17 AM
TACOMANATOR's Avatar
Can't help you with the heater but, if you have AC turn it on and crank the temp on the defroster. The AC will take the moisture out of the air and defrost you windows. If you dot have AC, hold your breath.
Old 12-04-2004, 07:59 AM
yamarocket630's Avatar
Possibly the blend door in the heatrer case (that directs air through or around the heater core) is sticking or out of adjustement. Also check that the heater control valve (under the hood right by the heter core inlet) is working properly
kawazx636
10-06-2021 03:03 PM
Kylenicoll33
12-10-2015 06:43 PM
83yotastockR
11
11-10-2015 06:54 AM
Ditch Doc
10-27-2015 03:20 PM
bryan34w
12
09-30-2015 02:50 PM
Quick Reply: It's cold in them thar' hills..
