| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
1987 Xtra Cab (4x4) - (SOLD) 22r, Rancho RS 5000, 15x8 American Racing AR-23s w/ 31x10.5 BFGoodrich A/T's, 2.25" exhaust w/ 23 1/8" glasspack, Explorer Pro Comp Prerunner bar/ Hella 500's |
#2 (permalink) | |
Quote:
#3 (permalink) |
It could be the throw-out bearing also...but if it was, the noise would change when you step on the clutch.
#4 (permalink) |
I was getting some intermittent squealing in one of my 22R trucks, totally random, over the span of several months. I finally pinpointed mine to a bad alternator bearing, it would drag a little and make the belt squeal. Replaced the alternator (it was shot anyway) and that cured it. Good luck on finding your noise!
__________________
98 Tacoma 2RZ 2WD XCab 167K miles, 84 22R 2WD SB 197K miles, 86 22RE 4WD Xcab 181K miles, 87 22R 2WD LB 302K miles, 80 20R 2WD LB 183K miles.....my "Fleet-o-beaters"! |
#5 (permalink) | |
Quote:
Strange though, because while the sound was evident yesterday, it never squeeked once today. I will see if it makes sound these next couple days.
__________________
#6 (permalink) |
Does the truck have AC?
#7 (permalink) |
No it doesn't have AC.
I am thinking it is the idler pulley bearing. I think because it is a generic bearing, it isn't designed to go that cold, so some of the oil in it probably got too thick and now that its worked through it with some warmer temps, its gone away. If it does come back, I will look at the alternator (god I hope not, I've spent nearly $1500 on this thing in 4 months). Thanks for the replies!
__________________
#8 (permalink) |
Hey, Dan-
It sounds like either a belt or an alternator bearing. The belts on my '83 squeel pretty bad. I need to replace them. When I had a Honda Civic as a commuter, the alternator bearing gave up. It squeeled until it warmed up, then it would just buzz. In your case, since it's RPM related, it would probably be the belts. Spray a bit of belt dressing on them and that should quiet them down until you replace them or tighten the tension.
__________________
Alan 1996 Supercharged 4Runner Limited Hi Altitude 4Lo A 4WD club for Colorado and surrounding states |
#9 (permalink) |
Banned for dupe accounts
Hey goodtimes though. Let me know if you ever need help workin on that truck of yours. Good luck with that squeel my speedo cable makes a rattling noise. Its nnoying but the radio covers it up.
<~~~~Still love that pic!!!! Last edited by scubasteve83; 02-15-2004 at 09:57 PM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Belts squeeling | MorphiasX | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 03-10-2005 01:31 PM |
| Squeeling noise??? | WSU4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 08-22-2004 12:18 PM |
| screeching/squeeling while driving | AznSky | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 06-01-2004 11:45 AM |
| New squeeling noise. | Scofco | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 03-09-2004 01:52 PM |
| squeeling belts | tep1974 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 11-28-2002 07:46 AM |
