installed new gauge cluster.. problems
Installed a new used cluster, swapped out the speedometer box with old so the miles would be accurate, however, the speedometer does not work correctly now.. inaccurate readings and fails to go back down. Suggestions?
If it were a later (electronic) speedo, I'd start by guessing your replacement came from a vehicle with a different # of cylinders. Since the '88 is mechanical, I'm guessing either a messed-up cable linkage or damage to the new cluster???... If the 'new' cluster is for a different application, maybe your swapped (original) speedo unit doesn't work with it?....
rushw
07-18-2015 01:46 PM
Poncho0206
07-10-2015 06:21 PM
