i need these flares
Old 03-13-2009, 04:38 PM
m3technic's Avatar
i need these flares
Why doesn't anybody make flares like this for a 3rd gen? Rear especially! this is rediculous i have been looking for flares for weeks, this should be easy but there is just nothing out there. i have 35's on mine that stick out too far for johnny law. i got pulled over for it and he gave me 15 days to fix it. well my time is almost up. i need flares now. i might end up having to make them. i just have no time. does anybody know if anyone makes them?
Old 03-13-2009, 04:44 PM
shaw_j's Avatar
If you are truly pressed for time use black crazy carpets to line the fender well.
It may not look pretty, but it will tide you over until you can find the ones you want.
Old 03-13-2009, 06:53 PM
m3technic's Avatar
thanks for the advice, but im not gonna make my runner look like poop because some cop is sad that his full size ford is smaller than my little 4runner. all i want are decent flares is that too much to ask?
Last edited by waskillywabbit; 03-14-2009 at 06:41 AM. Reason: Inappropriate Language edited
Old 03-13-2009, 07:01 PM
bigt's Avatar
jungle fender flares or jsm ones are the big ones.. ebay... or use the stuff they use for big rig trucks and trailers and make the flares..
Old 03-14-2009, 06:09 AM
jakob_in's Avatar
Like this?
You might contact user: Belize Off Road Team as they posed this pic 02-16-08 and might be able to help.
Also, you might try searching under "Hilux" or "Surf" as opposed to "4Runner". The Scandinavians and Europeans as well as the Australians seem to have lines on things like this.
Old 03-14-2009, 08:18 AM
MillerPKA's Avatar
Don't know why someone hasn't said it yet but Bushwackers are almost your only quick quality choice. They sell them on ebay but don't get any wider than the limited flares. Good luck
Old 03-14-2009, 01:35 PM
m3technic's Avatar
I spoke with the guy at jungle flares and he said the currently have nothin for the 3rd gen 4runner and the taco ones will not work. what is this jsm you speak of? and the bushwackers are no good.
Old 03-15-2009, 06:16 PM
m3technic's Avatar
BUMP!!!!!!!!!!! i neeeeeeeeeeeed flares now or i get in trouble.
Old 03-15-2009, 09:05 PM
Belize Off Road Team's Avatar
Replied to your PM, if no luck finding them in Japan, then i know for sure that Arctic Trucks out of the great white north will either sell them or make them, either way they will be your best bet.
Old 03-15-2009, 09:10 PM
berzerkrobot's Avatar
I have 3rd gen flairs on the front of my 97. 4.5inches wider than stock and 3 inches higher Click on my sig to see em.
Old 03-16-2009, 03:39 AM
trd_4runnin11's Avatar
What do you mean the bushwackers are no good? You don't think they are good quality or you don't like them? As MillerPKA said, if you want something quick without having to have something shipped from overseas or build your own, the bushwackers are gonna be your only option.
Old 03-16-2009, 09:34 AM
SnowRunner98's Avatar
fiberglass fenders up front, glassworksunlimited.com and mudflaps out back??
maybe some stock wheels and tires for the stupid inspection to buy some time?
Old 03-16-2009, 10:33 AM
racedirt1's Avatar
Agree with snowrunner98, do you still have your stock tires you can throw back on to buy you some time and get through the inspection?
Old 03-16-2009, 11:06 AM
If it is only for an inspection, then get some rubber, cut it to the width that your tires stick out, and bolt the rubber to the existing holes for fender trim. Then simply remove them after inspection.
Old 03-16-2009, 12:27 PM
Ron Helmuth's Avatar
landscaping edge trim
looks like crap but will get you past inspection
Old 03-16-2009, 01:03 PM
Toyvana's Avatar
Warn fender flares or bushwacker fender flares. Search the web, you'll find them.
Personally, I've had Warn fender flares on my truck for 13 years and they are still going strong. I had to make some cuts in order to fit my tires and I've taken them off once for a new coat of paint but they still look like new.
Old 03-16-2009, 02:59 PM
http://www.arctictrucks.com/Frontpag...s/Toyota/Hilux
http://www.supertrux.com/acatalog/Wheel_Arches_4x4.html
http://www.4x4at.com/product_info.ph...&product_id=95
http://cgi.ebay.com.au/ws/eBayISAPI....m=220376583279
Do you one better:
http://www.weds.co.jp/english/export.html
that is the contact info for the company that owns that white Surf posted earlier. Contact them and ask them what brand those wheels arch flares are.
http://www.streetbeatcustoms.com/Toy...Fender-Flares/
Old 03-16-2009, 03:52 PM
Godzilla's Avatar
Originally Posted by Belize Off Road Team
Nice searching BORT!
Second one down in the above link is perfect as it is for the surfs and is a 6 piece kit which suggests that it accomodates the rear door piece and would be ideal for your needs.
Old 03-16-2009, 04:03 PM
i personally love the "north pole" flares, massive flares for the mk2 hilux will fit the surf with minor modification to the rear flares.
Old 04-03-2009, 11:49 PM
blakegeee's Avatar
On the 3rd gen 4Runner, any "pick up" aka "Tacoma" aka "Hilux" flares will need more than "minor modification" to fit a 4Runner. Part of the single rear pick up flare needs to mount to the door and part need to mount to the rear panel. In other words, each 1 piece rear pick up flare would need to be cut in two. Once you do that, it wouldn't be simple to mount to the door since fender flares are hallow. I am not saying that it can't be done but it would be tricky. Also keep in mind that the front fenders on the 96+ 4Runner are unique to the pick ups also. From 96 on, the 4Runner has front fenders different to the Tacoma and Hilux. All 3 vehicle have totally unique bodies now.
For the 90-95 4Runners, we can special order the JDM style fender flares for anyone that needs them.
Zach_trun
01-22-2020 04:42 PM
94toyy
12
09-14-2015 06:18 AM
fabing455
09-07-2015 08:08 AM
justdifferentials
09-05-2015 06:52 PM
Quick Reply: i need these flares
