I Hate IFS!
I was working that notch. The steering, as usual, took a dump.
I have a 3.4 and a crawler. My steering broke on every trip I took for a year, over 30 trails and 3 states. It would break when I was hard on it and expected it. It would break when I thought I was being careful.
Oddly, the supposedly inferior rack and pinion trucks with similar equipment kept on cruising.
Are Heim-jointed tie-rods worth getting?
http://www.chaosfab.com/toyaccess_4wd.html
Will they work/fit with factory IFS?
The way I see it is, the IFS keeps you from doing dumb things with your rig. If you are braking your IFS then most likely you are pushing your vehicle too hard, running tires that are too big or taking your rig into terrain that it just should not go. If my theory is correct, then this guy would have had a much better day had he had IFS. http://www.metacafe.com/watch/39269/4x4_vehicle/
Originally Posted by Flygtenstein
Some of you may be familar with this pose. The last couple times, nothing was broke. This time that was not the case.
In case you want another look.
IFS, blah, blah.
IFS, blah, blah.
#26
#27
Back to thread: trail spares are still cheaper than a SA, but if you keep breaking over and over....cut it off and start complaining about expensive front end parts
kawazx636
10-06-2021 03:03 PM
83yotastockR
11
11-10-2015 06:54 AM
dirk89
10-01-2015 05:15 PM
JookUpVandetti
09-30-2015 08:58 AM
