how to remove overload leaf
Old May 25, 2005 | 12:10 PM
83 toy's Avatar
From: Nor Cal. between sac and tahoo in the foothills. a little place called amador county
im doing the chevy swap right now. i cant figure out how to get the overload leaf off the chevy springs. when you spin the nut there is a circular cap that spins with it. there is no way to stop the circular cap from spinning.
Old May 25, 2005 | 12:17 PM
JuttyShabango's Avatar
You have to cut that pin out and replace it. It will seperate the pack. Use a grinder and watch your toes.
Old May 25, 2005 | 12:36 PM
jimbo74's Avatar
for that circulat part, put a pair of vicegrips on it....
Old May 25, 2005 | 02:50 PM
Flamedx4's Avatar
VEry good idea to put some stout clamps on the springs before you do that. Some spring packs pop apart with enough force to seriously mess you up.
Old May 25, 2005 | 03:12 PM
4Crawler's Avatar
If you are talking about the center pin/bolt holding the spring pack together, a pair of vise grips works well, as mentioned above. Just grab the round end of the center pin with them.
Old May 25, 2005 | 04:14 PM
83 toy's Avatar
thank you i got some vice clamps and it worked fantastic.
next question: how can i get the original leafs out of the shackle/hanger? i have tried hitting it with a mallet, and alos tried prying the other side w/ a huge screwdriver. neither of which worked at all. ideas?
Old May 25, 2005 | 04:49 PM
4Crawler's Avatar
See the last Q&A topic in last January's Toyota Trails Truck Tech colum:
http://www.4crawler.com/4x4/TLCA_Tru...ech.04.01.html
Old May 25, 2005 | 05:27 PM
83 toy's Avatar
that really wasnt what i was looking for. but thanks anyway
anyone else have any opinions on how to get that bolt out?
Old May 25, 2005 | 06:14 PM
4Crawler's Avatar
Perhaps you could clarify what you are having trouble with. It sounded like you were having trouble removing the bolt from the spring hanger, but apparently it is something else.
Old May 25, 2005 | 08:28 PM
83 toy's Avatar
its ok i got it. just beat the ลลลล out of it with a hammer. took a while but it worked.
88sasturbotoy
Jan 30, 2026 01:57 PM
4x4-runner
Apr 18, 2017 09:08 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
Nickdigg
Jul 7, 2015 06:04 AM
