How to remove fog light bulb?
Old 07-11-2003, 01:18 PM
ssbogger's Avatar
Yeh, how do I do that?
Old 07-11-2003, 01:32 PM
TOR
Fog Lights
You have to get up underneath the bumper and remove the whole housing.
Todd
Old 07-11-2003, 01:47 PM
ssbogger's Avatar
so i do have to take out the whole assembly and take it apart. OK i just didnt want to do this and find out later that there was an easy way. Thanks
Old 07-11-2003, 02:40 PM
TOR
FOG
Yep they're a bugger! Just dont' brake the housing, the list on the part here for the housing alone is over $200.
Todd
Old 07-11-2003, 03:18 PM
pfdaxe's Avatar
SS:
There are 3 small phillips screws on the bottom of the housing. Remove them and pull the cover off to expose the bulb. There is a retaining clip holding the bulb in place. Pretty simple swap.
Old 07-11-2003, 03:26 PM
White SR5's Avatar
Never
I've never had to remove the housing... If it's the Hella Micro DE ones you are talking about, then you don't have to. All you do for those is pull off the rubber gromet, undo the wiring connection, and undo the retaining clip. No screwing, and can be done in under 1 minute. Now if you have the other kind of foglights I have no clue, I have the Hellas.
Zach
Old 07-11-2003, 03:40 PM
pfdaxe's Avatar
My 2000 came with the Stanleys and the only way to change the bulb is to remove the 3 screws on the bottom to expose the bulb. I would assume the 99's are the same. I didn't know they put Hellas in 01's??
Old 07-11-2003, 05:37 PM
ssbogger's Avatar
yeh mine had the stanleys
Shoua
13
05-22-2016 05:19 AM
09-04-2015 09:27 AM
Esibnitsud
07-30-2015 08:21 PM
rushw
07-18-2015 01:46 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: How to remove fog light bulb?
