How is this possible
Old 07-27-2003, 03:22 AM
03TundraTRD's Avatar
Ok I have a 2003 Tundra V6 with the elbow and the ISR mod.
My sister drove our parents has 98 4Runner 4x4 stock. We where going to our friends house and at a random stop light she REVVED on me.
And the light turns green she gets a jump on me. Her rear bumper is at my front fender after that we stay even all the way untill 80mph.
How could this be why is her 98 4Runner 4x4 faster than mine a 03 Tundra 4x2. When we got to our friends house she kept on telling me how SLOW my new truck is. I mean I brake tq @ 2000rpm while she just floored from a stand still. I check both our engines and she has only one cat converter and the tranny kick down cable. WHY:pat: did she beat me isn't the 4Runner rated @ 185 hp and 195 tq while mine is rated @ 190 hp and 220 tq.
Could it be that the 4Runner ECU is programed for a more agressive fual mapping than my tundra
Old 07-27-2003, 03:50 AM
White SR5's Avatar
Just kidding
It's probably because you weigh 200 lbs. and she weighs 100 lbs. Kidding by the way.
Zach
Old 07-27-2003, 04:10 AM
Zach
You are probably right:pat: but I doubt it. It's funny that I feel like I am writng to myself since my name is zach also.
Zach
Old 07-27-2003, 06:43 AM
Gadget's Avatar
Apperently she has skills and you don't.
Try more practice. When that doesn't work try checking to see what final drive gear ratios she has compared to yours.
Gadget
www.GadgetOnline.com
Old 07-27-2003, 07:13 AM
UKMyers's Avatar
Ouch
Old 07-27-2003, 09:18 AM
Plays_with_Toys's Avatar
Ummm, isn't the tundra the the biggest toyota pickup out? I would think that your weighs a few hundred pounds more. Does she have AC, power windows, locks and all that? Same ? to you. All those change the amount of weight in the car to the point you can notice a difference. More than likely it is just the weight issue, since you said you kept up with her after the initial get up and go.
Old 07-27-2003, 10:49 AM
turboale's Avatar
I'm with plays,
She just had a better launch... and there is no way she could have gotten a car length ahead of you at the start by just rolling on the gas and you brake torqueing at 2k. She must have been doing it too. Does she have a stick? That could have really helped her launch. Was your AC on?
Old 07-27-2003, 12:48 PM
NCSU-4runner's Avatar
WHY did she beat me isn't the 4Runner rated @ 185 hp and 195 tq while mine is rated @ 190 hp and 220 tq.
i wouldnt say 5hp or even 25ft-lbs of torque is enough to make much of a difference either way. with a difference that small vehicle weight is prob the main factor
Old 07-27-2003, 01:11 PM
EDGE's Avatar
Reasons why she beat you, 1 you have a V6 Tundra nothin wrong their but isn't the Tundra a heavy truck in general and 2 she probably weights in at 100 lbs which for a truck does not register at all so it was like you raced an empty 4Runner, you on the other had probably register double your weight, just simple physics how much gas did the both of you have cause that makes a different, ever race a slow car when it is on empty
Old 07-27-2003, 03:00 PM
Well both are auto and power everything. I KNOW she did not tq brake. , But the diff in weight is about 420lb. So I figure the truck needs to lose some weight and so do I. And the only other thing I can think of is that my trucks throttle butterfly is controlled by the ECU(Drive-by-wire) the 98 Runner is controlled by the throttle cable. It's just that the low end on a Tundra V6 is SAD it needs MORE grunt below 2500 rpm.
Old 07-27-2003, 03:05 PM
White SR5's Avatar
Talking WHAT?!
What?!?!?!?! You weigh 420 lbs?!?!?!?! Must have read something wrong hehe. I thought I was pushing it at 200 but man was I off! OK enough busting your chops... I'll stop. It is probably the weight difference in the vehicles though man in all honesty. So... your name is spelled with a "ch" too? I think that's the less common spelling. I've only met one other "ch" Zach before. Love peace and chiken grease!
Zach
Old 07-27-2003, 03:29 PM
I DO NOT weight 420lb the thats the difference between the 4Runner and the Tundra. TheTundra is 420lb heavyer than the 4Runner:pat:
Old 07-27-2003, 03:53 PM
EDGE's Avatar
I know why she beat you, a dude on TundraSolutions.com has a SC V8 Tundra and he races his friends Lightning, he says he is pretty even with him but after 80mph the truck lets off, like the gear ratio in either the trans or axle is just not set up to pull away at that speed.
He goes by the name of v8toilet
Old 07-27-2003, 05:29 PM
EDGE V8toilet is NOT supercharged I know this. All he has is a spintech muffler. I think you are refurring to mjoff He has TRD V8 S/C TRD Duals and Headers and the QTEC cut-out witha Unichip. His time was a 13.99. He's the one who raced a Lightning(I WANT one so bad):cry:
Old 07-27-2003, 09:24 PM
3.4v6's Avatar
does power shifting (shifting through gears manually on an auto) make a difference? i do that when i need to get up to speed *wink* ; i feel i can stay on the gears longer.
Old 07-28-2003, 04:04 AM
SLC Punk's Avatar
I think that on our transmissions, where you can pretty much redline it, the "power shifting" would have a negative effect.
But it did work well on my old 88 Monte Carlo with the 305 V8
Old 07-28-2003, 04:50 AM
Hyperlite's Avatar
Ask her to teach you how to drive
This should be a lesson, never try to beat a 4Runner
Old 07-28-2003, 04:57 AM
Hyperlite's Avatar
Shifting manually on an auto tranny is more effecient, but if you wait to late then the rev limiter will kick in and your shift will be slower. Rev limiters prevent the toy engins from blowing up, so give it hell
