How to Lift Body when Sliders already present
Old 03-21-2004, 06:05 AM
shazaam's Avatar
I'm trying to do this body lift, and in the instructions it says to use a Hi lift jack in conjunction with a block of wood. Well my sliders are already on, I don't think I can get the Hi-lift that close to the body to lift it off properly.
Should I get one of the hydraulic jacks, and stack some wood on there, and try it that way?
Any other suggestions would be appreciated
thanks
Old 03-21-2004, 06:52 AM
Hyperlite's Avatar
that would work just fine
Old 03-21-2004, 07:05 AM
I was able to place a bottle jack with a peice of wood on top on the tire to lift the body enough to get the pucks in.
Old 03-21-2004, 07:06 AM
AznSky's Avatar
That's what I plan on doing, except I have to drill holes in the frame for the aux. body mounts as well.
Old 03-21-2004, 07:08 AM
4runner4me's Avatar
I used the stock bottle jack and a black of wood. Just make sure what ever you put the bottle jack on is strong enough to hold your truck. We tryed some boards on top of a spare tire. The weight broke right thur the boards.
hope it helps.
pretty easy.
I think I hi lift would not work very good with or with out sliders. Unless you dont care about denting you body.
shazaam's Avatar
Thanks guys. Sears opens in an hour so I'll go get it then, and get started.
Old 03-21-2004, 07:24 AM
Bob_98SR5's Avatar
correct me if i'm wrong guys, but wont a BL w/ an already welded on slider not look that great b/c now the body will be higher than the sliders? i imagine if looks are not a big concern, then no problem.
bob
Old 03-21-2004, 07:28 AM
shazaam's Avatar
It might. But the only reason I'm doing the body lift now is so that I can order the correct size rear bumper from steve now. As soon as these tires wear down, I want to run 35" tires. Hence the need for the BL.
Old 03-21-2004, 07:33 AM
4Crawler's Avatar
You can also use a floor jack and wooden blocking:
http://www.4crawler.com/4x4/ForSale/...l#Installation
The sliders can be cut off and re-welded up higher once the lift is installed.
Old 03-21-2004, 07:38 AM
AznSky's Avatar
bob
Except for my case the reason for putting on the BL is because the sliders are too high
Old 03-21-2004, 07:43 AM
RTdawgs's Avatar
we put some 4x4s in between the sliders and used a floor jack.
IMO, sliders look better when theres some room between the body and the sliders. my buddy runs a 2" body and he got his sliders built so that there was about 2" between the sliders and the body and they look great!
Old 03-21-2004, 07:48 AM
shazaam's Avatar
correct me if I'm wrong here. The sliders are welded to the frame. I need to loosen the bolts between the frame and the body, and then lift the body off of the frame. How would I be able to lift the frame by placing boards under the sliders and lifting from there?
Old 03-21-2004, 07:53 AM
Albuquerque Jim's Avatar
Put the boards above the sliders (I just slid them in) and use a hydralic jack (or your stock spare jack). I used some blocks to get the jack up high enough. It's pretty simple once you get going. I just did the 1" BL last week.
Old 03-21-2004, 07:55 AM
RTdawgs's Avatar
put the boards below the frame, not the sliders.
see Jim's post...
Old 03-21-2004, 08:15 AM
calrockx's Avatar
hope it helps.
pretty easy.
i used a hi-lift when putting on my lift, thought it'd be just fine. we used towels to protect the body, but still the process left a very slight dent in the driver's door from the hi-lift touching the body. not a big deal tho, it's out now. so if you're going to use a hi-lift anyone, just be very careful about it.
Old 03-21-2004, 08:39 AM
shazaam's Avatar
ok just picked up a 3 ton hydraulic jack from sears for $50, and a 122 pc tool set for $80.
Let me eat something and I'll get started and post here as I go along
Old 03-21-2004, 09:40 AM
shazaam's Avatar
k where is this steering shaft clamp or rag joint that I'm supposed to loosen and then later on insert the extension into?
I looked at the pic in the 4crawler site, but I can't figure out where under the truck I am.
Old 03-21-2004, 09:49 AM
4Crawler's Avatar
The rag joint should be at the steering rack end of the shaft. There may be a plastiv boot covering that area, if so slide it up and out of the way. The clamp is at the top end of the shaft, where it passes through the firewall.
Old 03-21-2004, 10:02 AM
shazaam's Avatar
Is this it right here?
click here
Old 03-21-2004, 11:20 AM
4Crawler's Avatar
click here
Yep, that's the rubber rag joint and the clamp, looks like your clamp is on the same end as the rag joint, some are on the opposite end. Remove the two short bolts (not the pressed in studs) and slip the spacer in over the stud ends and install the new longer bolts. Adjust the length with the splined clamp and tighten it all down.
Quick Reply: How to Lift Body when Sliders already present
