YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-27-2008, 10:50 AM   #1 (permalink)
AmyRW's Avatar
Send a message via Skype™ to AmyRW
How to get a smoother ride on my '98 4Runner
I just bought a '98 4Runner SR5 and it bounces me all over the place. I'm used to driving a '04 Nissan Armada that is so smooth. What can I do to make this '98 a smoother riding vehicle. I know I need new tires anyway and that will make some difference, but I'd honestly like to have the ride of my Nissan if possible (or as close as I can get). Any suggestions???
__________________
'98 4Runner SR5 2WD 4 Cyl., 152,xxx mi.
Upgraded '99 Limited Leather seats 1/2 done
Working on '99 cup holder mod. w/ blue illumination
“The fool hath said in his heart, There is no God. They are corrupt, they have done abominable works, there is none that doeth good.”- Psalm 14:1
AmyRW is offline
Sponsored Links
To remove this ad, register today!
Old 03-27-2008, 10:55 AM   #2 (permalink)
cackalak han's Avatar
New tires won't do much. You will need to swap out the whole suspension system (struts, shocks & springs). Are you wanting a lift at the same time? OME kits are good. Check out rocky-road.com or trdparts4u
__________________
01 Tacoma DC TRD OR 4x4
cackalak han is offline
Old 03-27-2008, 10:55 AM   #3 (permalink)
Dare44's Avatar
get new shocks, mine doesnt bounce but it is pretty stiff with the Old Man Emu nitrocharger shocks
__________________
1997 Toyota 4x4 SR5 4runner
3.4 auto
Toytec 3 inch coil spring Lift
Trail Gear Rock Sliders
Maxxis Bighorn M/T's
Amp Custom Rims
Cobra CB, 5ft Firestik
KC Daylighters
http://www.cardomain.com/ride/3008195
Near Future List
Bumpers
Lockers
1st Gen Roll Bar
Winning the Lottery?
Dare44 is offline
Old 03-27-2008, 11:04 AM   #4 (permalink)
X-AWDriver's Avatar
I'd stick with OEM (Tokico shocks) which means it still won't ride like your Armada which is solely designed for the street. I've also heard Monroe Sensa-trac shocks are pretty soft for a 4Runner.
__________________
'99 4Runner Highlander 4wd
E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs
Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub
X-AWDriver is offline
Old 03-27-2008, 11:08 AM   #5 (permalink)
AmyRW's Avatar
So, it's going to be a little costly?! If a lift gives me a better ride that is fine, but it's not a requirement for me.
__________________
AmyRW is offline
Old 03-27-2008, 11:10 AM   #6 (permalink)
Dare44's Avatar
with my toytec lift, it is new, it rides better altho u have to slow down more for cornering. i didnt lift it to be a race car tho.
__________________
3.4 auto
Amp Custom Rims
KC Daylighters
Near Future List
Bumpers
Lockers
1st Gen Roll Bar
Dare44 is offline
Old 03-27-2008, 11:23 AM   #7 (permalink)
Sonoran Steel SYSTEM 3.0 KIT is $550 for all shocks and springs. OEM 1999 parts which should give you 1/2 to 1" lift over your 98 (if 4wd. 1.5" to 2" on a 2WD)
http://www.sonoransteel.com/store_co..._liftkits.html
blarchitect is offline
Old 03-27-2008, 12:31 PM   #8 (permalink)
dirtypuke's Avatar
what i have noticed if i run more air presure (35psi) it makes my 4runner ride like a tank but i get better mpg, but if i run 28 psi it really smooths it out. i have 265 75 16 michelin ATs though. tires make a huge difference depending on load ranges and rubber compounds.
dirtypuke is offline
Old 03-27-2008, 01:38 PM   #9 (permalink)
AmyRW's Avatar
I've got 31x10.50r15LT 109Q on it right now.
__________________
AmyRW is offline
Old 03-27-2008, 01:50 PM   #10 (permalink)
X-AWDriver's Avatar
Quote:
Yikes,prices have gone up;just two years ago I bought my whole '99 setup for around $410 shipped from Conicelli Toyota and even their price is now $544.
__________________
Old 03-27-2008, 10:32 PM   #11 (permalink)
I was planning to go to the 99 suspension route, but what I have found through researching with people who has this set up and over the internet is that it still bottom out with the extra 1/2" to an 1" increase thus I went for SS system 7.2 for comfort and rideability.
thmpr is offline
Old 04-02-2008, 02:00 AM   #12 (permalink)
AmyRW's Avatar
My husband did let some air out of the tires and it has helped. It was riding like a brick - even killing us over the cracks in the road. My husband was looking Rancho shocks, potentially the quick-lift. Does anyone have any advice or thoughts on this?
__________________
AmyRW is offline
Old 04-02-2008, 12:58 PM   #13 (permalink)
mpavolka's Avatar
The springs you have are going to be pretty soft, the best and least expensive way to achieve a better ride only would be to get new shocks. Shocks go bad on a regular basis and would lead to the bouncing around, and if yours are stock, ten years is pretty old. Rancho shocks are decent but they will not ride the best, they are fairly stiff, Bilstiens are very good and even stiffer. My advice would be to go with Tokico Trekmasters, they will give you a better ride on and off road with more stock ride feel.
__________________
99' 4Runner SR5 5spd 3.4L
Sonoran Steel 7.1/7.2/OME891
Previous Vehicles: 1985 4x4, 1990 4Runner
mpavolka is offline
Old 04-02-2008, 01:03 PM   #14 (permalink)
Check out the "Comfort" shocks/struts and springs from OME.
__________________
Old 04-02-2008, 01:53 PM   #15 (permalink)
AmyRW's Avatar
Thanks all for the advice. I certainly don't want to be disappointed by a stiff ride after changing the shocks!! I guess I've been spoiled by my Armada!!!
__________________
AmyRW is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Softer Quieter Smoother Ride? bozz 86-95 Trucks & 4Runners 19 03-19-2008 06:40 PM
what can i do for a smoother ride?? MONEY_MIKE 95.5-2004 Tacomas & 96-2002 4Runners 14 07-08-2006 11:25 PM
AT transmission smoother in the cold? rdiggidy 95.5-2004 Tacomas & 96-2002 4Runners 7 02-03-2006 01:10 PM
Advice for a smoother ride 4RunnerFever 95.5-2004 Tacomas & 96-2002 4Runners 20 10-08-2005 05:47 AM
4runner ride height?? Xpresident 95.5-2004 Tacomas & 96-2002 4Runners 1 10-04-2004 11:22 AM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
