How crzy/hard would it be...
Old Nov 16, 2004 | 03:44 PM
ianshoots's Avatar
So I came back to my home town the other day...today i saw that a guy I sorta know is selling his 99 pre-runner. I don't now if he's aware that is has an e-locker, but I sure am. Would i be nuts to try and buy it from him? Would it be a huge deal? I know it would be a certain amount of work, but wouldn;t I essentially just switch our third members? (sounds kinda dirt don't it..). He could probably drive away pretty quickly,l whilst I tried to figure out the wiring.
My primary concern is that it would not be a problem to leave him with a perfectly driveable (just not lockable) truck.
Any thoughts?
spanks,
Ian
Old Nov 16, 2004 | 03:48 PM
User 051420's Avatar
As far as I know, you can't just switch the 3rd's. The non-trd ring is an 8.4" while the TRD one is 8". You'd need to switch the entire axle, and possibly the front to match gearing.
Nab the locker ecu and switch too.
Old Nov 16, 2004 | 04:42 PM
ianshoots's Avatar
Crapola. Probably too big a deal, since its not like the donor is a junker.
Keep saving for that ARB...
Old Nov 16, 2004 | 04:46 PM
BLKNBLU's Avatar
Check in with 96runner. He did a swap recently. I think he just bought the donor though the re-sold soon after. Not sure bout the details, but he'll have details on gearing, wiring, what to look for, etc.
Old Nov 16, 2004 | 04:56 PM
superjoe83's Avatar
if you have an auto, then i bet that the ratios are the same and it would work, i would go "look" at it and see if the axle codes are the same
Old Nov 16, 2004 | 04:57 PM
Flygtenstein's Avatar
You cannot just swap the thirds, there is a lot more going on than that. It is not just a bolt and go deal.
Old Nov 16, 2004 | 05:04 PM
justinh's Avatar
Originally Posted by gapguy
As far as I know, you can't just switch the 3rd's. The non-trd ring is an 8" while the TRD one is "8.4". You'd need to switch the entire axle, and possibly the front to match gearing.
it is the other way around, all e-lockers are 8" while the 8.4 resides in non-trd tacos and tundras.
Old Nov 16, 2004 | 05:11 PM
ianshoots's Avatar
I now this question gets asked about thousand times a day here, but where do i find the axle codes?
I guess I'll ask him how much he wants for it, then look for 96runners thread on the swap (I ran across it once before).
Old Nov 16, 2004 | 06:28 PM
BLKNBLU's Avatar
A couple axle code links
http://www.off-road.com/toyota/taco/...axlecodes.html
http://www.off-road.com/toyota/tech/other/4_axles.html
Good luck
Old Nov 16, 2004 | 06:32 PM
If you have an open diff'd Taco right now, you cannot, under any circumstances, get that third in your current axle.
You have an 8.4" diff, like all open diff'd Taco's and all Tundra's.
The e-locker is an 8" diff like all 4-Runners.
Old Nov 16, 2004 | 06:33 PM
OOPS..yes..thinking one thing, typing the other.
Old Nov 16, 2004 | 06:36 PM
rimpainter.com's Avatar
Yeah, I swapped the entire front and rear axles/diffs from a donor rig to mine and vice versa. If there is anything you need to know or have any specific questions, let me know and I will do what I can to help.
I bought the donor rig for $10K, swapped the front and rear as mentioned, then re-sold the donor rig for $10,300.
If you pull an ECU from an ABS equipped donor rig, it will trip the ABS light. Therefore I could not grab the locker ECU from the donor rig. I had to buy one off Jim here on Yotatech.
The best way to check the ratio is to jack up the rear, mark the shaft at the third, and have someone spin a wheel two full revolutions.
My ratio was different than the donor rig, hence the front and rear swap requirement.
Old Nov 18, 2004 | 04:31 PM
ianshoots's Avatar
I might look into this. it wouldn't work at all for me unless the ratios were the same, because the donor is 2wd. He's asking 9,00 obo, its a 99 with 90k on it....
talar883
Aug 30, 2019 12:30 PM
ErikZ1220
Sep 10, 2015 04:53 AM
Ryan Zoltan
Sep 17, 2013 07:02 PM
