HELP!!!!!!!!!!!!!!!!!!Still wont start - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-07-2004, 06:35 AM   #1 (permalink)
:pat: After doing the deck plate mod my truck won't start. Let me give you the full break down of what I did. Cut the hole in the airbox, washed out plastic shavings with maf sensor still inside ( i know I shouldn't have done it but the one screw would not come out). Put it all back together and this is when I had problems. The truck will start only for about two seconds. I cleaned the MAf with electrical cleaner and I reseated the EFI fuses. It seems like its not getting fuel. My next move is to get and Olmmeter and test the MAF. A new MAF is about $150 that I don't want to spend if i don't have to. Help before I spend the $$$$$$$$$$$$$$$
cobrahunter is offline
Old 08-07-2004, 09:34 AM   #2 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Quote:
I would try starting the truck with the MAF sensor disconnected.....worst case is that it will throw a CEL and tell you the MAF is disonnected. That way you can see if the problem is actually related. Be sure to go over everything you actually touch (possibly even by accident) during the mod to see if you knocked any wires loose or anything is not attached properly. Just a bad MAF sensor is usually not enough to make the truck unable to start (I am assuming the truck turns over fine but just won't fire up).
Did you maybe pull a fuse and forget to put it back in?
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 08-07-2004, 10:03 AM   #3 (permalink)
Samgotit's Avatar
Check all of your vacuum lines near where you were working if any and the connection b/w air box and throdle body.
Your symptoms sound like loss of vacuum.
Sam
__________________
"Common sense is the collection of prejudices acquired by age 18. " - Albert Einstein
Samgotit is offline
Old 08-07-2004, 10:29 AM   #4 (permalink)
gapguy's Avatar
Send a message via AIM to gapguy
If it will start for only 2 seconds, I'm willing to bet it IS your maf sensor. It's super delicate, and I bet it got damaged. The truck should however still run, just terribly. Start it, and give it gas, I bet you can keep it running (crappy, but running). Good call on testing the MAF.
__________________
2008 Mini Cooper
gapguy is offline
Old 08-08-2004, 06:42 AM   #5 (permalink)
Thanks
It worked! I tightened everything up one more time just to make sure. I started the truck and she still didn't want to run , but I kept giving her gas and then she decide to purr like a kitten. All it took was a little gas and the computer getting used to the extra air coming into the air box. THANKS for all your help!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
wont start please help 95yota4 86-95 Trucks & 4Runners 5 06-25-2007 08:04 PM
3.0 wont start 4rnr 86-95 Trucks & 4Runners 18 03-19-2007 10:30 PM
Recently rolled 4-runner now it wont start, why wont it ?? gtpunk18 86-95 Trucks & 4Runners 22 01-24-2007 10:25 PM
it just wont start tk0218 86-95 Trucks & 4Runners 2 03-06-2006 05:50 AM
wont start headhunter 95.5-2004 Tacomas & 96-2002 4Runners 8 02-02-2004 04:10 PM
2009 InternetBrands, Inc.
