Last edit by: IB Advertising
- Toyota Tacoma Transmission Diagnostic Guide<br>Guide to diagnose trouble and recommended solutions.
help! 95 Toyota Tacoma v6 3.4l 4wd automatic transmission
So went to store and when i pulled into parking lot and got out left truck idle while i ran in and when i got back outside i could hear a lound grinding sound from motor turn off truck and back on was quite for about 20 sec and its back lound grinding sound. On the way home i had no power steering and batt light comes on when i turn to the left. When i got home opened the hood to look and see if I can pinpoint the sound but nothing noticeable can anyone help!!!!"
Ok so I found out the problem. Did some research and found some stuff on harmonic balancers. So I had to go look and sure enough loose real loose. Removed the belts. And it was just hanging, but the bolt is tight. Can i just get a new HB.
Yes, you will need a new HB, IMHO. Also, the timing belt (TB) will need to come off so the crank gear can be pulled so the key can replaced (it's mangled in pic 1).
Might just be a good time to do the TB, etc. if it's getting close to the next change interval.
Not cheap.
http://www.toyotapartsoverstock.com/...340862040.html
For that kind of money, I'd consider a salvage yard.
I think you'll need to carefully examine the key-groove in the crankshaft. It it has been banged up, the key won't fit tightly, and the wobbling of the crankshaft pulley will quickly loosen everything.
Good luck!
Good luck!
kawazx636
10-06-2021 03:03 PM
LCE_Performance
10-01-2015 01:03 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
