HELP! 92 3.0V6 Rnr Dies out. No cmptr reading
Old 11-17-2005, 09:13 AM
Greenbush's Avatar
Unhappy HELP! 92 3.0V6 Rnr Dies out. No cmptr reading
PLEASE HELP!!!
Can someone please help me. I have a 92 3.0 V6 Rnr auto that I have been trying to fix and I can't run down the problem.
I would run great for a while and then it would just sputter and die off. I replaced the fuel pump and it did not help. I checked the diagnostic code steps and nothing registers. It just keeps blinking.
When the engine was running, if I was lucky enough to be around it, I would hear a click near the ECU and then it would sputter out. I used to be able to start it up a little while later. It would run and then do he same thing.
Again, the diagnostic code check does not register anything.
Someone has had to have the same thing, or similar, happen. Is it my coil, a relay etc.
Old 11-17-2005, 10:17 AM
ajutan's Avatar
If i would you, i check power supply including battery, fuses and connectors close to fuel pump area, specially ground wire.
Old 11-17-2005, 10:33 AM
JamesD's Avatar
On my 87 I had a wire I think it was going from the battery to the fuse box under the hook came undone since it was crimped by the factory. It was a solid blue wire. Like he said, check all power and grounds.
James
sandyota
02-04-2021 11:16 AM
Sleaker
08-26-2020 06:03 AM
Doug4320
03-24-2018 10:11 PM
Yota.Jay
07-23-2015 08:08 PM
Jonny246
07-12-2015 04:51 AM
Quick Reply: HELP! 92 3.0V6 Rnr Dies out. No cmptr reading
