| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
gear change
#2 (permalink) |
4.56 will make you faster off the line, but limit your top end speed more. Your engine will work a little harder to cruise than it did before. Mpg will go down.
Your cams, well that's just a matter of preference, what you intend to use the vehicle for, etc. A more aggressive cam will tend to worsen your mpgs. However, if you're running 33s and 4.56s I'm guessing this isn't a daily driver? If so, and you want good mpgs, but a small car and save the yota for the trails. YES, ABSOLUTELY YES, your gears in the front and rear diffs MUST MATCH. You will destroy stuff if they don't match. Have you set up gears before? -Wrench |
#3 (permalink) |
I would opt for 4.88's or even 5.29's. Your truck should get better milage and clutches should last longer. Im assuming your truck came with 28" tires stock it would be safe to say that 4.88's would have your truck performing like it had 28" tires on it again.
If your truck did come with the stock 235 or what ever it is tire then although your speedo is reading say 65 you are actually going about 76 miles per hour. You will notice more recorded miles per gallon as well since you are only recording about 85% of the actual miles you travel. In the older trucks the speedo is cable driven off the back of the T case so the speedo only counts rotations of the drive line and has no way to calibrate for tire size difference. If your one of those 65-70 miles per hour guys on the freeway I would say go 5.29 and you will be very happy with the new found "get up and go" around town and not having to shift down to 3rd or 4th for every little hill any more.. If your one of those 85-90 miles per hour on the freeway guy then go 4.88's. Either way you will probably see more improvment from the gearing than any cam will ever show you. if you want to play with gearing equivelants look here for some intresting calculators to play with..... http://www.nyjeepin.8k.com/calc.html edit.... above poster is absolutly right in saying that you front and rear differential gears MUST match if you plan on using 4wd at all. If you use 4wd with say 4.88's in the back and 4.10's in the front you will probably only go about 6 ft before the front tnd of your truck tries to drag the rear end. Think of it as the ole 2 person horse costume in the school play, Both people must walk at the same speed and if one stops the other will either drag or push the slower one. In the 4wd world we call this drive train bind and it WILL break somthing in a very short time (say 50 feet?)
__________________
1990 Xcab beast of burden 3.0 Rebuild/Precision balanced w/OS valves Custom ported/welded Intake manifolds Downey headers, Jacobs Ign 4" Trail Gear SAS + rear Kit R151 + Dual cases (2.28+4.7) 5.29's,Tru Trac/Lockright on 35 BFG's 140A GM CS144 alt/Hyd assist steering DOA Racing = $1200 lesson in who NOT to deal with Last edited by Ganoid; 02-21-2005 at 12:35 AM. |
#4 (permalink) | |
Quote:
and something I've been wondering about for a while
__________________
2000 4Runner SR5 Intakesilencer removal, deckplate mod, elbow removal, 1'' Roger Brown Bodylift', 1'' BAMACHEM Lift, OME N91S shocks and rear coils, OME N86 front shocks, tundra front coils, s/s brake lines, Sonoran panhard bar, Sonoran diff drop, Daystar bumpstops,TJM-17 front bumper, Stubbs Sliders, 255/85 BFG Mud Terrains, Sonoran Rear Bumper, Hella 500's |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Can I change drive/gear ratio? | aquasport17 | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 03-27-2007 08:48 PM |
| Tranny Gurus: A340H 4th gear change? | elripster | 86-95 Trucks & 4Runners | 7 | 03-08-2007 09:28 AM |
| gear oil change | 91TPU | 86-95 Trucks & 4Runners | 5 | 01-06-2007 02:05 PM |
| Synethic gear lube change interval | Buster | Newbie Tech Section | 3 | 04-06-2006 12:05 PM |
| Anyone change their speedometer gear? | VolcomTacoma | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 09-03-2004 07:45 PM |
