gas gauge
Old 02-13-2006, 08:14 AM
kodit0103's Avatar
gas gauge
hey guys whats up. 99 4runner 4wd, stick, 3.4L. my gas gauge is stuck and it wont pass 1/2 tank. I am having to go on my odometer based on mpg, and its a total pain and had closed calls to running out of gas. The toyota stealership wanted 720.00 to fix it. Do you guys know if it is really hard to fix it, and if it is this expensive? thanks a lot.
Old 02-13-2006, 08:37 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
Search for and read about TSB EL010. That MAY explain your problem.
Old 02-13-2006, 12:19 PM
Deathmage's Avatar
Mine is stuck as well, but it off and on. started happening a few month after i bought the car, brand new.
Old 02-13-2006, 12:24 PM
cracker_1's Avatar
Mine wouldn't read below a quarter of a tank, hence we ran out of gas after buying it. Found the problem to be a bad ground to the sending unit. An easy fix, without removing the tank. You can access the sending unit thru the access hole below the rear left seat. Might give it a try if nothing else works.
Old 02-13-2006, 12:47 PM
Godzilla's Avatar
where do you attach the new ground to (one external and one to ?the original ground wire? do you have to open up the unit? or is the sending unit external of the tank? any pics?
Old 02-13-2006, 12:56 PM
Godzilla's Avatar
http://www.larsdennert.com/4runner/fuelsender/index.htm
heres one with pics...where do i attach a new ground?
mussy01
12-13-2016 08:20 PM
Nickyodaman
07-27-2015 12:13 AM
Tyler Cunningham
07-11-2015 10:18 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: gas gauge
