Fuel Pump/FP Relay locations...
I guess this kinda kills the whole idea behind it, but I am planning on putting a manual fuel pump relay cut-off, the idea behind this is to be able to simply throw a switch/relay, to prevent theft... This works well from what I've seen/heard on other cars, if broken into and successfully stolen it makes it froma couple feet to maybe a block before it stalls out, at this point the theif cant really afford to try to fix it.
If anyone can point out an easy (does that ever exist) way to get to the fuel pump, or if there is a fuel pump relay, any help would be greatly appreciated
On the driverside, there's a harness underneath the plastic floor panel running along the door opening, just put a switch in to turn off the pump. I forget exactly which wire it is, I'd have to look it up.
